Home wheel alignment
Old Feb 5, 2015 | 12:23 PM
GoldenOne's Avatar
GoldenOne
Default Home wheel alignment
Anyone use a wheel alignment system that is reasonably priced and easy to use? I have seen online and t.v. Quick Trick. Anyone with personal experience or another product?
Thanks.
Old Feb 5, 2015 | 07:13 PM
RussM05's Avatar
RussM05
Thanks.
I checked toe using jackstands, conduit, fishing line, and machinest ruler. Took time to get it set up, but it was very accurate.
That being said, for about $80 I can get a local shop to do it with a good Hunter machine. Not worth doing it myself anymore.
Old Feb 6, 2015 | 11:49 AM
savage's Avatar
savage
i just had SPIEGLER SS brake lines put on my car, at the time i asked (wheels are off car jacked up) for him to remove washers from behind A- ARMS on top( there are two washers behind each bolt, i had one removed) 16 off, 16 still there, this is the way the 2015 owners manual said to help get more neg camber, washers are thick, as some of us know the rear of the c7 tows out when you go past -1.0 camber, i hope the autocross alignment goes a little better than last year with washers(shims) gone. now to the point, i dont want to use a stick and string for alignment, i want a before and after printout from someone i trust ( their are shops that play games out there, they will hit print before they tighten it up!), alignment means a ton for many reasons-track, tire wear, ect. i also pay $80.00 and a case of beer from my brewery job.
Old Feb 6, 2015 | 11:55 AM
Kracka's Avatar
Kracka
$80 is very reasonable for a GOOD alignment! $90-100 seems to be the range I'm typically paying.
Old Feb 6, 2015 | 12:25 PM
01vetter's Avatar
01vetter
No mater what tool you use you have to have your car on a LEVEL surface. This isn't easy to do on a garage floor. This is what you get with an alignment machine (if they check it regularly). Also, make sure that your tires are all inflated to the proper level.
Old Feb 11, 2015 | 11:25 AM
MIGHTYM0USE's Avatar
MIGHTYM0USE
i made these on the side at my work
relieve the bottom so that tire bulge doesnt affect positioning. leave a flat section in the middle to rest or mount an angle finder on. this one i had, i would prefer more resolution.
Old Feb 11, 2015 | 03:39 PM
ChucksZ06's Avatar
ChucksZ06
The problem with alignments are the guys operating the equipment. The tech/mechanics skills are far more important than the machine.
Old Feb 11, 2015 | 05:00 PM
11B250's Avatar
11B250
exactly... that's why u have to know the reputation of the place you take your car to... Half these people can maybe do a regular car alignment.
To Home wheel alignment
