Does this picture look like my headers are leaking?
Old Feb 13, 2015 | 06:46 AM
leadville1's Avatar
leadville1
Default Does this picture look like my headers are leaking?
They are doing the Cam and Head swap and sent me some pictures. As I look at the first port it looks to me like exhaust is potentially leaking from the first runner. I re-used the stock gaskets when I had them installed. Or is this normal?
Old Feb 13, 2015 | 07:20 AM
leadville1's Avatar
leadville1
Here is a picture of the actual head, it sure looks like a leak to me.
Old Feb 13, 2015 | 09:25 AM
robertf97's Avatar
robertf97
I agree it's a leak. Ask if the bolt was loose when they undid it. If so try a new gasket and locking bolts. Inspect the header for flatness with a straight edge, if it's not flat, return it or have it trued or you can use a thicker gasket. There may be copper or dead soft aluminum gaskets that will hold up better.
I did all of the above on my F-body with cheapo pacesetter headers. It's why I went with ARH this time. Good luck.
Old Feb 13, 2015 | 09:35 AM
VNAMVET's Avatar
VNAMVET
Veteran: Marine Corps
I believe those are ARH........
Perhaps he could have used the ARH gaskets that were supplied with the headers instead of using GM stock gaskets.......?
Old Feb 13, 2015 | 10:05 AM
Kracka's Avatar
Kracka
Looks like a minor leak, just use new gaskets this time around.
Old Feb 13, 2015 | 10:35 AM
FYREANT's Avatar
FYREANT
I'm Batman..
Pro Mechanic
Old Feb 13, 2015 | 01:49 PM
leadville1's Avatar
leadville1
ARH is sending me their gaskets for install, the installer that did the initial install didn't want to use them he thought they would leak, so he re-used the stock gaskets.
Hopefully this will solve the issue.
Old Feb 13, 2015 | 02:36 PM
robertf97's Avatar
robertf97
Good luck. The stock gasket has metal on it (below) and the ones I got from ARH didn't so I didn't use them.
Old Feb 13, 2015 | 02:55 PM
leadville1's Avatar
leadville1
Nick at ARH was pretty confident that I use theirs but I have had two people tell me they wouldn't use anything but stock.
Old Feb 13, 2015 | 06:09 PM
dovervold's Avatar
dovervold
Leadville, mind telling us more about the heads/cam you are going with? I am putting my 14' under the knife in a month or so, and would like to see what kind of results people are getting. Seems like heads/cam/LT's will net 600-630 crank HP pretty easily... Tks, Doug
Old Feb 13, 2015 | 07:34 PM
leadville1's Avatar
leadville1
I am putting in the Texas Speed package, DOD Delete, VVT II Cam with Ported and Polished heads, De Witts Radiator, 170 Degree Thermostat, C7-R Racing Timing Chain, ATI Damper, Ported TB and a Custom Tune.
I also am putting on the Wilwood 4 Wheel brake kit, this car is going to be my road course car.
Old Feb 14, 2015 | 03:29 PM
EcoBrick Bob's Avatar
EcoBrick Bob
Dazed Confused & Verklemp
We re-used the stock gaskets when we installed headers on both of my G8's with great results. Haven't had to re-tighten the bolts yet in 4 years! Just cleaned them up and used a quality gasket sealant when installing.
Old Feb 15, 2015 | 10:25 AM
leadville1's Avatar
leadville1
Is it worth using the Stage 8 Locking header bolts?
Old Feb 16, 2015 | 11:54 AM
T/A KID's Avatar
T/A KID
NICE, I assume you jumped on the special price??? I PMed Jason this morning and I believe I am going to do the same package. Those heads are killer, did you get them milled any?? What size cam did you go with. Those power goals should be easy to hit.
Doing my own custom cam on the deal if I can, be roughly the same size as a Ls9/Zr1 cam.
Old Feb 16, 2015 | 11:58 AM
T/A KID's Avatar
T/A KID
ALWAYS use new header gaskets, just use the factory bolts they will be fine.
Haven't used the stage 8 locking header bolts since SBC's
Old Feb 16, 2015 | 01:50 PM
leadville1's Avatar
leadville1
It is on it's way to my installer right now. They are installing all my upgrades at once. Brakes, Head/Cam kit etc.
To Does this picture look like my headers are leaking?
