8 speed auto trans issue
Old Feb 23, 2015 | 05:57 PM
vetteboy15's Avatar
vetteboy15
8th Gear
Default 8 speed auto trans issue
I love my 2015 C7, but despite all the hype about this new 8 speed tranny, I am convinced that there is an issue that needs to be addressed. I hear a fluttering sound that sounds like it is coming from out of a hollow tube just below and behind the driver. It seems only to happen at around 1500 rpm. I can get rid of it by either accelerating thru it or downshifting. When cruising on the tollway at 75 mph I'm at 1500 rpm in 8th gear, and the noise is very annoying. Now if I drop it to 7th the noise disappears! This is total BS! I drove a few other new vettes on the lot w/ the GM mechanic, and they all had a similar but not as noticeable sound. He had no answer. My theory is that GM engineers programed the shift points at too low an rpm in an effort to increase mpg. I cannot believe that I am the only one w/ this issue, and I am determined to get to the bottom of this. This should not be happening. I never heard anything like this in my 08 C6. Somebody suggested that it could be torque flutter. I never heard of that. Does anyone have an idea?
Old Feb 23, 2015 | 09:08 PM
PRE-Z06's Avatar
PRE-Z06
Nvh?
Old Feb 23, 2015 | 09:15 PM
NSC5's Avatar
NSC5
AFM active? Does it do it in manual mode (select manual shift mode then "paddle" back into 8th so that speed/RPM is the same but AFM cannot activate).
Old Feb 24, 2015 | 10:59 PM
tblu92's Avatar
tblu92
St. Jude Donor '13-'14-'15
I also suspect the AFM is causing the "fluttering sound" Test as suggested would be to drive it in MANUAL mode and see if the same sound appears---As in manual mode the AFM is disabled---
YES however these cars are very high geared and shift extremely early--causing the engine to lug badly---But realize with VVT the engine can handle the lugging without any detonation---As a previous muscle car owner it's tough to drive around town with the engine running at 1200 RPM's --I couldn't stand it---A full tuner with EFILIVE or HP can adjust and raise all your shift points --More importantly GM LOCKS the converter from 4th gear on up which makes it lug even worse---On a A6 I always delete the lockup in all the gears but 5th and 6th---And on an A8 delete the lockup in 6th 7th and 8th--This gives you the TQ multiplication of the converter thru all the lower gears and eliminates the lugging---Plus makes the car so much more responsive when driving at P/T and flooring it
Old Feb 25, 2015 | 09:22 AM
hxrly's Avatar
hxrly
No noises on mine, and I drive a lot with my radio off listening to the car; however, I did disable V4 mode.
Old Feb 25, 2015 | 09:30 AM
Kracka's Avatar
Kracka
Agreed with AFM being the cause. The noise you hear is likely caused by the engine dropping to and running in V4 mode. If it bothers you that much, I'd suggest you either put the car in manual paddle mode or disable AFM. I love how they do AFM on the M7 (only in Eco mode), but disagree with it being active in all modes on the A8 cars (seems odd to me, they should at least have it disabled in Sport and Track modes).
Old Feb 25, 2015 | 10:20 AM
xp800's Avatar
xp800
Add me to the suspected AFM mode. If you really want to know how awful it can sound, pull the AFM valve fuse. Welcome to tractorville.
All the above recommendations are good ways to diagnose. Also you can use the center DIC display to see when it's in V8/V4 mode. One of the Performance screen pages with the instant econ reading will display engine mode: V8 (orange), V4 (green), and V0 (white, engine off...LOL).
As others may have mentioned, you can disable AFM through a tune, but that brings other potential consequences. The most transparent and reversible is the DiabloSport InTune/Trinity. You can adjust many parameters in including AFM whether or not you install the tune. Also the recent posts by Trifecta with their tune look interesting as they can control the A8 now. The DS couldn't control the A8 initially and not sure where that stands.
Old Feb 25, 2015 | 01:09 PM
crabphir's Avatar
crabphir
I had the exact same issue with 2015 C7 auto! Dealer replaced both rear exhausts. Basically stating it was the bi-mode valves fluttering on seat. I just had it replaced and I thought it was fixed but then I thought I heard again this weekend. Its clearly not as bad as it was because I could make music with the kazoo! It would also occur around 1500-2000 rpm in 4th+ gear.
Now I am thinking is the tranny.
Old Feb 25, 2015 | 02:16 PM
Kracka's Avatar
Kracka
It would be worth taking a ride in a M7 in Eco mode to see if the sound you hear is the same.
Old Feb 26, 2015 | 01:19 PM
vetteboy15's Avatar
vetteboy15
8th Gear
It doesn't matter what mode I'm in or if I'm in V4 or V8. The sound is there around 1500 RPM. If I paddle shift down to increase RPM the sound disappears.
Old Feb 26, 2015 | 03:10 PM
vetteboy15's Avatar
vetteboy15
8th Gear
Being in V4 or V8 has no effect on the noise. It happens in all modes around 1500 rpm.
Old Feb 28, 2015 | 09:20 AM
axr6's Avatar
axr6
From the RPM descriptions it could also be a very slight drone from the exhaust at those RPMs. When you change RPMs by shifting the noise goes away. Quite common in V8 engines with aftermarket exhausts but, for a finely tuned set of ears, may even be audible with stock exhausts.
Old Mar 2, 2015 | 11:49 PM
Tommy D's Avatar
Tommy D
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
St. Jude donor in memory of jpee '14
If the car is equipped with the NPP option and it is set to open all the time it is possible. There are times when my 14 does drone until the npp valves close. On my C6 (npp) with the vacuum lines blocked off it droned at 1500 rpm.
Old Mar 3, 2015 | 03:48 PM
DOUG @ ECS's Avatar
DOUG @ ECS
Premium Supporting Vendor
From: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
Consider a Diablo In Tune to shut of the AFM and give a performance upgrade at the same time without voiding the warranty. We have plenty in stock if anyone is interested. Sounds like that's your issue, but of course without seeing it... GLWI
Old Mar 6, 2015 | 05:14 AM
dealtimeman's Avatar
dealtimeman
So the programmer use on car won't void the warranry?
Old Mar 6, 2015 | 09:21 AM
sycraft's Avatar
sycraft
It will if you take it in with the tune loaded...
Old Mar 6, 2015 | 09:28 AM
Kracka's Avatar
Kracka
You just have to flash back to stock before going in to the dealership.
To 8 speed auto trans issue
Old Mar 7, 2015 | 06:50 PM
wantac6's Avatar
wantac6
I have the exact same noise. It really pisses me off and gets on my nerves. My local dealer claims that it is a normal sound from the exhaust.
Old Mar 23, 2015 | 10:11 AM
ArcticC7's Avatar
ArcticC7
I have it too.
Old Mar 23, 2015 | 01:56 PM
vetteboy15's Avatar
vetteboy15
8th Gear
Originally Posted by ArcticC7
I have it too.
We need for everyone with this issue to call the Corvette Owners Center number listed in the warrantee book. The number is 800-222-1020. They will issue a case number. If there are enough complaints, maybe they will issue a recall.
