***New stock shortblock boost only record***
Old Mar 13, 2015 | 12:06 PM
Detoxx03's Avatar
Detoxx03
Originally Posted by on3wego
Yea that's why I posted boost only.
Didn't know 1320 had a badass c7.
I'm just really proud of everything. I may have to retune and take my lash cap back out. Buddy blew his motor. And thinks that's the cause of it. So may get re dynoed
Saw that happened to him last night. Knowing Justin it will come back even stronger.
Originally Posted by Ron@Vengeance Racing
I was talking about the silver wrapped C7 that belongs to Justin from 1320Video.com .... He has an F1 Pro Charger on a stock bottom end and is making over 900RWHP.
Justin doesn't work for 1320Video but he is friends with Kyle who does own 1320Video. He's co-founder of Street Car Takeover and il is car made 810.
Old Mar 13, 2015 | 12:18 PM
Ron@Vengeance Racing's Avatar
0Ron@Vengeance Racing
Former Vendor
Pretty sure he made more than 810rwhp the other day😂
Old Mar 13, 2015 | 12:30 PM
robertf97's Avatar
robertf97
Why does he think the lash cap blew up his motor? I ask because I have one with a +32% fuel lobe. What kind of fuel lobe was he running? How much boost, etc? Thanks!
Old Mar 13, 2015 | 12:38 PM
Detoxx03's Avatar
Detoxx03
Pretty sure he made more than 810rwhp the other day��
Last I saw it was 810 but I see that it was over 900 more recently. I stand corrected on that.
Old Mar 13, 2015 | 01:14 PM
on3wego's Avatar
on3wego
He actually made 840 now. He put bigger nozzles in his meth kit. And lash cap. So he was able to redline to 6500 and made the 840.. I made 840 with 12 lbs. I now make 908. At 15 lbs
Old Mar 13, 2015 | 01:15 PM
on3wego's Avatar
on3wego
Yeah I seen it last night to. And he texted me. He will come back with over 1000 rwhp I'm sure. And Ron he doesn't make 900 rwhp.. yet anyways.
Old Mar 13, 2015 | 02:42 PM
hnaskoct's Avatar
hnaskoct
Well Tell me this guy's making 700 to the wheels..is that pretty easy to do and last???
Old Mar 13, 2015 | 03:23 PM
Detoxx03's Avatar
Detoxx03
It's easy the same way it was with a C6. The key to it lasting is having a good tuner.
Old Mar 13, 2015 | 03:47 PM
on3wego's Avatar
on3wego
This^ tuning is key. 700 rw is pretty easy on these cars. But tuning needs to be spot on.
Old Mar 13, 2015 | 03:50 PM
on3wego's Avatar
on3wego
Me and stangkilr both have 32% fuel lobe. We think it's the lash cap bc he been running his setup for thousands of miles. Racing and non racing with no problems. But as soon as he put lash cap in (last week) then his car blows up.. we think it made the mechanical fuel pump fail and motor run lean and boom. Can't prove it was the lash cap. But it's a good theory at this point
Old Mar 13, 2015 | 04:06 PM
robertf97's Avatar
robertf97
Thanks for the reply. If that is the case, he should be able to see some damage to the pump, lash cap or fuel lobe when he takes it apart.
Old Mar 13, 2015 | 04:34 PM
ProChargerTech's Avatar
0ProChargerTech
Former Vendor
When Justin stated he was going to add that cap onto the top of his already overdriven cam lobe, I voiced concerns about the pump bottoming out.
Since I have never installed one, I didn't know for sure however just like valve springs for cams, they can only go so far before bad stuff starts happening.
That car has been beaten on since the day we started shipping systems. From all the videos online, to the dyno days, and street racing in "mexico" it just seems fishy that it literally started having drivability issues the second that lashcap was added, and then BOOM.
Old Mar 13, 2015 | 05:55 PM
  #33
stangkilrproductions's Avatar
Originally Posted by prochargertech
when justin stated he was going to add that cap onto the top of his already overdriven cam lobe, i voiced concerns about the pump bottoming out.
Since i have never installed one, i didn't know for sure however just like valve springs for cams, they can only go so far before bad stuff starts happening.
That car has been beaten on since the day we started shipping systems. From all the videos online, to the dyno days, and street racing in "mexico" it just seems fishy that it literally started having drivability issues the second that lashcap was added, and then boom.
this^^^
Old Mar 13, 2015 | 05:58 PM
  #34
Theta's Avatar
Theta
St. Jude Donor '14-'15
Any other elements to the equation when you changed it over?
I'm certainly interested (and sorry for your loss) - just have not seen any other issues on a lot of cammed C7s with Comp lash caps.
Old Mar 13, 2015 | 06:24 PM
  #35
I beat the crap out of mine for 10k miles that the blower and cam was in the car. It has been making 750+ since July 2014. I just find it funny to me that after installing the lash cap not even two weeks ago my engine blows up bad on a easy 2nd gear pull that I shut down at 5,000rpm's.
Old Mar 13, 2015 | 07:40 PM
  #36
Theta's Avatar
Theta
Totally understand. The problem with nailing down issues is that sometimes these cars just have weird problems that pop up at the strangest times. Take my thrust bearing problem @ 400mi, for example - had we not torn into it, I could have easily thought something else with the cam install caused the engine to go.
Not saying this is the same in your case, but I think by now we've all seen some weird stuff on our first-batch cars.
I'm on your side - just trying to gather more information. The postmortem should give more insight into what happened - I know you've got to be even more interested than the rest of us. Always a bite to not know what takes you down, but we can all take info away from other losses.
Old Mar 13, 2015 | 09:33 PM
  #37
nenzi71's Avatar
nenzi71
I believe the cam increases the pump travel by 1.5mm and the lash cap might be another 1mm. So how much travel does the pump have before the plunger runs out of travel and bottoms out in the pump???????
To ***New stock shortblock boost only record***
Old Mar 13, 2015 | 09:58 PM
  #38
on3wego's Avatar
on3wego
That sir is a good question. I'm not sure of the whole travel. Maybe Theta has some info on the mechanical pump? On the c7 and the z06 style
Old Mar 13, 2015 | 10:01 PM
  #39
Theta's Avatar
Theta
Above my pay grade - would be interested to know, though!
Old Mar 14, 2015 | 02:14 AM
  #40
on3wego's Avatar
on3wego
I believe I may just upgrade the pump, hardlines and injectors soon. Just for peace of mind
