Service Rear Axle code on the dyno
Old Mar 13, 2015 | 03:28 PM
Newton06's Avatar
Newton06
Default Service Rear Axle code on the dyno
Fluid level is fine, all connectors good. Keeps coming on after 2 - 3 pulls.
Bad pump?
Also wondering if the code causes the car to go into limp mode as power seems to fall off.
Any help appreciated!
2015 C7 7-speed Z51 3k miles.
Old Mar 14, 2015 | 11:13 PM
tblu92's Avatar
tblu92
St. Jude Donor '13-'14-'15
Bad pump?
Dyno runs often trigger false codes----Mostly traction control and ABS--because the front wheels are standing still and the rears are going over 100 MPH---so the ECM thinks the fronts are locked up skidding----Possibly with an E-diff. the ECM is thinking the same thing--
If it goes away with normal driving--most likely that's all it was--
Old Mar 15, 2015 | 02:20 PM
runutzzzzz's Avatar
runutzzzzz
Check the battery cables, make sure they are nice and tight.
Old Mar 15, 2015 | 10:54 PM
xp800's Avatar
xp800
Perfectly normal. Happened on all 4 of my dyno sessions. Message went away before I was even out of the parking lot afterwards. I didn't notice any changes on the rollers. Pulls done in track mode with TC off (hold TC button).
To Service Rear Axle code on the dyno
