Forgive me for double checking...Torque Specs
Old Apr 3, 2015 | 01:00 AM
NC94Vette's Avatar
NC94Vette
Default Forgive me for double checking...Torque Specs
I am changing out my Z51 rotors and I have found the torque specs for the front caliper bolts at 162 ft lbs and the rears at 89 ft lbs.
Seems weird for two reasons. My C6 Z06 was the same front and rear and it as like 127 ft lbs. So to me, 162 seems really high and it also seems a bit odd to have two different specs for front and rear. I know that I am going to get yelled at for asking, but I am looking for confirmation from guys that have done it before.
By the way, it looks like I am going to have to remove the rear wheel air deflectors to have room to move the calipers enough to get the rear rotors off. Just two screws to remove the deflector?
Any other tips?
Thanks.
Tom.
Old Apr 3, 2015 | 01:41 AM
Theta's Avatar
Theta
St. Jude Donor '14-'15
I checked again just now to see if anything had changed, and it still shows the same figures. Does seem like a lot, though.
Old Apr 3, 2015 | 08:15 AM
NC94Vette's Avatar
NC94Vette
Thanks much for double checking! It just seems like anything north of 150 ft lbs is inordinately high. (I guess I won't worry about using any blue liquid thread locker!) And I hope my impact wrench is up to the removal task...
Old Apr 3, 2015 | 09:40 AM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
Dayem! That's some major torque on a bolt! I agree to the numbers from the Helms but I have seen Helms to be wrong especially on torque numbers.
Elmer
Old Apr 3, 2015 | 06:57 PM
NC94Vette's Avatar
NC94Vette
Quick follow-up ... all four rotors are replaced. The impact wrench grunted a bit, but it did it's job. I had tested the front bolts with my torque wrench at increasing levels (150, 155, 160 ft lbs) just to see what the factory torque was. I seemed like at 160 I got just a very slight movement. Given variability of torque wrenches I am convinced that the 162 ft lbs spec is right.
I didn't end up using the impact wrench on the rear caliper bolts. No way to get it in the tight quarters with the airflow diverters. Since those bolts are only torqued to 89 ft lbs, I could break them free with a 15 MM boxed-end wrench and a hammer. Torquing them back to 90 ft lbs required me using a smaller torque wrench again because of the tight space. But it all worked.
So today was all about getting my process re-calibrated. I used to do the street/track switch-over on my C6 Z06 pretty much in my sleep. This C7 Z51 has lots of differences, but by the end of the track season, I will once again be napping as I do the switch. lol
Old Apr 5, 2015 | 12:51 PM
FYREANT's Avatar
FYREANT
I'm Batman..
Pro Mechanic
this info helped me. thank you
Ant
Old Apr 5, 2015 | 08:55 PM
NC94Vette's Avatar
NC94Vette
Ant
You are quite welcome. This forum is a great place. I am always appreciative of the stuff that I find from other's experiences.
Old Apr 29, 2015 | 09:52 AM
Car54's Avatar
Car54
Do you have a torque setting for the torx screw that holds the rotor to the spindle? I think it is a T-30. Also, Theta's how to did not specify any loctite on the rear caliper bolts and I did not see any when I removed mine. Did you put any loctite on the rear and what kind...red...blue?
thanks
bill
Old Apr 29, 2015 | 01:33 PM
Theta's Avatar
Theta
Bill, replied to your other post. I will put both of those up for you in just a few minutes.
To answer your question, the front brake rotor bolt is specified at 106 in lb, and the rear brake rotor bolt is specified at 89 in lb.
Old Apr 29, 2015 | 01:41 PM
Car54's Avatar
Car54
Theta
Thank you very much. I really appreciate it.
Bill
Old Apr 29, 2015 | 02:05 PM
Theta's Avatar
Theta
Not a problem:
Front: https://www.corvetteforum.com/forums...ke-rotors.html
Rear: https://www.corvetteforum.com/forums...ke-rotors.html
Old Apr 30, 2015 | 05:42 PM
FormulaRedline's Avatar
FormulaRedline
What other parts are you switching for track days?
I did my first in my car earlier this month. I found the stock brakes slowing the stock front tires to be lacking. I didn't really notice when doing the school at Spring Mountain (also on stock parts), but I guess it's more apparent at a track that I've driven in other cars.
Are you using track specific pads? It sounds like you are switching rotors? What wheels and tires have you tried?
If you are switching between street and track, what about alignment? Just leaving it in track alignment permanently?
To Forgive me for double checking...Torque Specs
