How much to get headers installed??
Old Apr 4, 2015 | 09:36 AM
Jack Be Quick Racing's Avatar
From: Detroit area and Nashville area What day is it? Between MI & TN
Default How much to get headers installed??
I am seriously thinking of pulling the trigger on some ARH mid-length headers sooner than I had planned to...
What is the going rate for labor / cost for installation?
Old Apr 6, 2015 | 06:46 PM
anyone?
Old Apr 6, 2015 | 10:10 PM
richysvette's Avatar
richysvette
St. Jude Donor '12, '14
My shop is charging me $300 but that was with a supercharger and tune also so maybe I got a little bit off.
Old Apr 8, 2015 | 11:28 PM
AD2386's Avatar
AD2386
I called this one clown high performance shop he wanted $750 to install the headers and $750 for tunning. So $1500 I told him no way! $1000 is more than a fair price to install and tune.
Old Apr 9, 2015 | 01:17 AM
CDH76's Avatar
CDH76
Get a buddy and install them yourself! No lift? Raise that sucker up as far as the jack stands will go. Take off the wheels and lay them down under the car. That way if the car drops it lands on the tires. That is what my buddy and I plan to do when I order a set. He did it on his camaro solo so I think one more set of hands and you are good! Then just think with that money you save you get a tune and CAI
Old Apr 9, 2015 | 02:17 AM
MikeLsx's Avatar
MikeLsx
750 to install headers ? geez
Old Apr 9, 2015 | 01:25 PM
thrilled's Avatar
thrilled
This is hearsay but I've been told that on the passenger side they have to be put in from up top.Need to remove the starter and other things.
Old Apr 9, 2015 | 02:09 PM
CDH76's Avatar
CDH76
Yeah I have read mixed results on installing them on a z51. Only one way to find out!
Old Apr 11, 2015 | 04:18 PM
11B250's Avatar
11B250
I'd like to know too. I would assume 500 or so, but I have no idea.
Old Apr 11, 2015 | 04:25 PM
js1977's Avatar
js1977
I think my install was $300 and the tune was $600, but I was also having a Procharger installed as well so the tuning wasn't as simple as just with headers.
Old Apr 11, 2015 | 05:26 PM
thrilled's Avatar
thrilled
There was A place near Orlando said for purchasing them,installment is free.
These were B&B headers.But I've been hearing 3-4 hour labor.
Old Apr 12, 2015 | 06:03 AM
PARANORMAL's Avatar
PARANORMAL
SUPPORT AUTISM
St. Jude Donor '10, '14
Had my headers installed at ARH. It took them about 5 hours, hourly rate is going to vary from shop to shop. On a lift, both headers were removed from the bottom. Even though I have installed headers before, after watching the guys at ARH, I 'am glad that I paid to have it done.
Old Apr 12, 2015 | 03:56 PM
Dangerous Don's Avatar
Dangerous Don
Just for everyone's info I just finished installing ARH long tubes and x pipe on my z51 and there is absolutely no possible way to drop them in from the top. A z51 is a dry sump car and you will need to remove the starter and the dry sump lines to be able to install the headers, I found out the hard way and scratched my ceramic coating up a lot prior to removing the dry sump lines. When removing the lines remember that you will lose about 3-4 quarts of oil so make sure you either catch the oil for reusing or buy more oil to replace what you lose.
Old Apr 13, 2015 | 03:41 AM
MikeLsx's Avatar
MikeLsx
good lord.
Old Apr 13, 2015 | 02:46 PM
thegame's Avatar
thegame
I would assume all the good shops know this though, correct?? Like ECS
Old Apr 13, 2015 | 05:00 PM
TennisFreak's Avatar
TennisFreak
Just installed long tube headers on my buddies 2013 1LE Camaro this Saturday.
Took about 4 hours (with us taking our time and also learning what to do as it was our first time) and we used 4 jack stands.
It was fun and relatively easy. He had bee quoted $400 for the install by a local shop.
Old Apr 13, 2015 | 05:50 PM
thrilled's Avatar
thrilled
That's probably about right.Near $100 an hour 4 hours $400
To How much to get headers installed??
Old Apr 13, 2015 | 08:45 PM
AD2386's Avatar
AD2386
I called another shop in Phoenix today, was quoted 7 hours labor @100. So with tune and oil change was $1500 and they said they need the car for 2 days. Yikes!!!
Old Apr 13, 2015 | 09:20 PM
BLKTA's Avatar
BLKTA
Yeah, header install on a 5th gen Camaro are easy.. they practically install themselves because of the room.
Old Apr 16, 2015 | 05:22 PM
JDP Tech's Avatar
0JDP Tech
Former Vendor
The going rate tends to be about $500 in labor, plus shop materials and we usually do an oil change on the Z51 cars.
Best regards,
Tyler
888-308-6007
