Why Isn’t Airflow Increasing With Intake Mods?
talking about the maximum cfm of a bore and stroke at a given RPM without taking into consideration anything else is pointless. an engine doesn't run by holding a piston in your hand and swinging it around in the air at 4000 RPM (if you could).
i don't need to reread your question because I know exactly what you are asking and it is not an intelligent question. what i don't know is why you are asking it. if you dont know the answer, there are an unlimited amount of calculators available online. if you do know the answer then that's good for you but there is nothing you can do with it. characteristics of airflow just do not work that way.
How long is a piece of string?
basically, don't talk to me. I am under no obligation to converse with you and you are free to block me from your view. I don't set myself up as anything, I answer questions I know the answer to and read about the ones I don't.....so given the percentage of threads I participate in, I know a lot less than you seem to want to imply I think I do.
I don't treat everyone like this, just you and one or two others. if you think I am an auto mechanic, then that's great. it means you have some respect for my expertise. I mean, this is a tech section on a car forum, what would you rather discuss? foreign policy? macroeconomics? I'd LOVE to talk physics with you.
or don't talk to me, that's fine too. or, if you want to use this exchange as grounds for starting over with each other, that's always an open door with me. if you really want to talk about volumetric efficiency then we can.....you can't go from *** to nice guy in one post. at least I'm an *** all the time, I'm consistent.
and with all due respect, have a nice evening.
More airflow requires more commanded fuel----
you say you are a tuner. please tell us what shop you work for so people know.
Actually, that number is in line with the 13% additional fuel number you quote. Sounds like the AFE requires a tune to use.
if you want to say something, say it. if you have something to teach the forum, teach it. I can't decode your posts and I am not inclined to elaborate on supposition.
spit it out man.
During PE or at WOT is totally different---The fuel is at the mercy of your commanded fuel in your tune---Before the AFE my WOT AFR was around 12.7 AFR on the widen]band in 3rd gear---Which is safe but these engines can be run leaner and safe
After the AFE install the WOT AFR went to way lean--similar to your's in the low 14's---The ECM also pulled timing and it showed about 19-21 * of timing only due to pinging----
My conclusion is that the AFE re-location of the MAF sensor and the more free flowing air intake required adding fuel--I chose to do that by adding fuel with the MAF table from 6500 HZ on up---I started by adding 3%---Immediately the timing came back to the 23-24 range and the air flow measured an increase---which equals more HP
I then added again another 3% with the same results--airflow increased as well as timing into the 25-26* range--Wideband now shows an AFR back into the low 13's ----No KR or no pinging either---
When I have time I will again add more fuel to shoot for a safer 12.7 to 12.9 area---These engine like fuel---These changes were all done on GAS---after the E85 conversion I've noticed that the timing has increased into the 27-28* range---still no KR and pinging---haven't checked the AFR with the ethanol yet---But I am guessing that the added fuel will only create more airflow and HP---
These E92 ECM's are complex---tuning to date requires trial and error---Bottom line with the AFE--the stock tune needs more fuel to make more HP--otherwise you lose a lot of timing as mine did into the 19's---Right now I'm at a plus 6% on the MAF table above 6500 HZ results have been great--timing has jumped into the 25's and the airflow shown by the MAF has jumped into the 50 lb area---( stock was in the 46 lb area)
Others may have experienced different results---these are only what my experience has shown--
The point I'd like others to take from this is that the AFE intake is not plug and play. You will HAVE to tune the car to run one.
Your comments make me think that this engine might pick up a little from octane, if the timing self-adjustment window is that big I'm curious if anybody has tried 97 or 100 octane and logged the timing.
seriously guys, this is still an engine that pumps air tuned by gm. the only change is the ecm is torque based instead of airflow based, for calculations.....the 2000 corvette could benefit from octane and so could a 2015 truck. fuel trims are the same as always.
heres the difference.....people are starting to understand and talk more about whats inside the computers now. its just a sign of the times. but we arent discovering something new.
no different than any previous vette or camaro.....or truck.
The coyote could not however swing the timing 8 degrees as was indicated in this thread, it had the ability to go 2 degrees each way. Unless it was a super hot day or something 93 octane was enough to max out the 2 degrees of advance, so more octane got you nothing. If this car can keep advancing it until there's knock then I'm mixing some 110 the next time I go to the track.
I asked the top guys on the fast list what fuel they ran and nobody answered lol, maybe now I know why.
