NPP Reverse-Engineered - Full Open/Close, Non-Factory-NPP Retrofit
#181
This kit works, I bought mine from this guy, board connectors and all.
#183
I am currently working on a new controller which will require no installation of switched. It is controlled from an Android Phone (and maybe iPhone in the future) using bluetooth.
This is an early prototype simple to prove the system works. I have nearly everything I need to build a working prototype except for the 5 pin plugs.
Here is a video of my proof of concept and is where I am at so far. It is fully functional but not practical and far from pretty.
The following 4 users liked this post by mayhem2408:
#184
I'm Batman..
Pro Mechanic
This is an early prototype simple to proof the system works. I have nearly everything I need to build a working prototype except for the 5 pin plugs.
https://youtu.be/jodcE-Cxfoo
I had mine on the first setup with always hot power and it was hard switched with a toggle switch by my right leg. If I forgot to turn it off, it would obviously kill the battery. Except for the high pitched sound you get from the valves having power running to them you would sometimes not even notice the were on (closed position). The same sound I hear in you clip when you activate them.
Where are you planning to tap in to power for this since there is no existing wiring for you to tap in to? Also I would recommend not tapping in to the 20A fuse for the 12V accessory plug as many are already tapping that for their methanol systems.
#185
The biggest challenge with this is (I have a true retrofit so speaking from experience) is that in order to be able to start the car up with the valves closed you have to use either always hot power and remember to turn the valves on before start up (and off after you park the car) or you have to find an switches accessory power source and then you have to go through the whole process once the power is on.
For me, I will simple tap off the accessory power as I don't draw much current there. But if this causes a problem, the above method could be used. It's personal preference where people tap their power from and will be different for different vehicles. I plan to have the ability to set via Bluetooth to ability to power up using the previous valve state, or power up with the valve closed, or power up with the valve open (Saved in the Arduino EEPROM). All this is planned and not implemented yet. I have simply designed a basic circuit and Arduino code to control the valve to prove the it will work. Obviously this project is in its very early days, but I think the end result will work out great.
FYREANT (02-21-2018)
#186
https://www.arrow.com/en/products/1-...FVA8Twod6j4HTw
the manufacturer part number is 1-1718806-1 and is also available from several other suppliers such as mouser.
The following 2 users liked this post by red 1:
FYREANT (02-24-2018),
mayhem2408 (02-26-2018)
#187
Hey thank you for this!! Much appreciated
Here is the link for the 5 pin connectors.
#188
#190
#192
Tried to message Theta to see if it's possible to buy any of these parts but so far no response. Does anyone know if he's selling?
Also tried smola but message says his inbox is full.
Thanks.
Thanks.
#194
FYI for those interested in building a breadboard circuit. I think I discovered a discrepancy between the circuit schematic diagram and the breadboard layout. I built a breadboard according to the schematic and could not get it to work (measuring frequency with an oscilloscope), so I reviewed the first breadboard design and discovered that the duty cycle resistors connect to the +10 volt line rather than the 10k resistor as shown on the schematic. I made the change and it worked great. PM me if you'd like more details.
ht_pro (05-12-2018)
#195
I'm Batman..
Pro Mechanic
ht_pro (05-12-2018)
#196
Thanks in advance for any insight!
#197
I can provide the schematic and BOM. All parts are available on Amazon except the valve connectors which are available at DigiKey or similar electronic parts suppliers. Access to an oscilloscope to test the performance is recommended. An inexpensive one that I use (Hantek HT6022BE20Mhz) is also available on Amazon. As soon as I complete, I'll post the parts list and schematic.
This is the breadboard layout provided by Theta that I used.
FYREANT (05-12-2018)
