Track alignment
Old May 1, 2015 | 01:06 PM
GoldenOne's Avatar
GoldenOne
Default Track alignment
Going to track tomorrow was wondering if I just took of some of the washer on the upper control arm evenly, will that give me more negative camber without causing change in toe and caster? Would it be noticeable or worth doing on short notice. Thanks
Old May 1, 2015 | 04:24 PM
5thGear's Avatar
5thGear
I don't think so but I am not an expert. You need alignment work. you need tie rod end adjustments to get the right camber and toe.
I am going to the track tomorrow as well (Fontana CA). I called few dealers and they didn't know what track alignment/ prep is. I told them I just need them to follow the manual which I will provide. One dealer told me that this will void the car warranty!!!
I did the oil change, dot 4 brake fluid and cooling rings. I gave up on track alignment for tomorrow since I cannot get it done today.
Old May 1, 2015 | 05:25 PM
descartesfool's Avatar
descartesfool
If you take washers out, that will change the camber. It will also change the toe at the same time, so you can't do that. You would need a proper alignment. If you drive aggressively with stock alignment, you will wear out the outside edges of the tires. I know, I trashed my Z51 front tires in one day, in particular the left front since dealer said he couldn't do alignment (old machine) and I had the track day booked the day after the alignment booking. Rear tires were OK. New front tires with shipping, mount and balance cost me more than the track day, so I wouldn't do that again.
Old May 1, 2015 | 05:37 PM
GoldenOne's Avatar
GoldenOne
my outer edges are pretty thin. So if pull washers and adjust toe I might be ok. How many degrees camber can you get from the washers?
Old May 2, 2015 | 01:37 AM
RedZ's Avatar
RedZ
Dealer did my car the other day. They pulled the washers, took them about 5 hours to figure out they needed to do that, and another 2 to finish. They got pretty close to 2014 track spec (I didn't know it updated for 2015).
Front L/R -2.0/-1.7
Rear L/R -1.7/-1.6
Left side was to spec, right was a bit off.
Old May 3, 2015 | 09:38 AM
Mad Dog 24's Avatar
Mad Dog 24
From: Syracuse-Central Square New York Winer of the all Corvette race WGI 8/23!
Try this, get the track alignment done tell the technician to mark every washer removed left, right front and rear. Color code each washer so you know exactly where it goes back. Mark with paint exactly where the toe is set on the tie rods front and rear.
Go back for your street settings and do the same. With a little time and energy you can set your track alignment yourself and save major dollars. Beware suspension components are stressed on the track and move, bend, twist I've seen everything! I would go to the shop every 4 or 5 track days to have the machine gauge it to determine the settings are still accurate or not. Porsche Boxsters on the track would bend their steering knuckles so much we would replace them after a certain amount of time for fear of cracking!
I know this is not the perfect way to do it but not everyone has a 30k alignment machine in there garage or 100 bucks plus to spend on every track then back to street alignment.
To Track alignment
