Road Course Upgrades Review DeWitts, Wilwood Z06 Grills
#81
I just spent two days at Road America...
...DeWitts Radiator - The radiator made a tremendous difference on the track, my water temps never went over 220 degrees even after a 30 minute session, the highest oil temp I saw was 210 degrees. While cruising on the highway my water temps hover at 190-200 and my oil temps are staying around 180 degrees. This single upgrade solves your cooling issues.
Bingo and ceramic coat your headers. That is what I have.
Temps are fully under control with what I have done to mine. The DeWitts by far made the biggest change. Even in 80 degree heat in traffic with the air on the temps are staying at 200 degrees water and around 200 oil.
So, it is the high RPM, heavy load performance of the DeWitts radiator that I would like to read about. If you (or anyone) could comfirm that the DeWitts would keep my temps down under those conditions, I'd be happy to purchase one and not worry about temperatures any more.
Thanks for your posts on the subject.
#83
Received 2,382 Likes
only on the radiator and probably any coolant leaks in the future will be pinned on the radiator (even though it isn't related). also anything that happens during installation would not be covered, like broken tabs, missing screws, etc.
I like to have my dealer install the mods I can't do in the garage. they are happy to help.$$
#84
Were you driving in the upper RPM ranges (4-6k) for the full 30 minutes on the track? You are showing some surprisingly low oil temperatures for track usage. I always figured that the oil cooling would be the main problem but, if the DeWitts radiator alone brings those numbers down this much, all the better!
I don't have ANY issues either with the water and oil temps with my stock C7 under normal, low RPM driving conditions even exceeding 90 degrees ambients. Just like your numbers above. However, as soon as I raise the RPMs and put some load on the engine, particularly in lower, 2nd or 3rd gears, the oil temps skyrocket to 300 degrees within a very few minutes while the water staying around 230-240 degrees.
There are a few tricks to installing it. They had to install some spacers in my hood vent to get it to clear without interference and they trim where the mounting brackets go slightly.
I can't imagine owning a Z06 and not having this radiator. For a Z51 it makes it far better at heat management on the track.
#85
Trust me I live at high RPM's and full load for the entire session at the track and the DeWitts is keeping it cool. There is NO downside to this modification.
#86
my experience with upgrades this weekend
I have done the following upgrades so far:
dewitts radiator, LMR 160 tstat with adjusted fan settings, header wrap and oil cooler heat shield. My car is Z51 M7 with procharger.
I ran streets of willow springs temp 90 deg weather.
I was able to run all 4 sessions. Staying in 3 and 4th gears mostly. My highest temp oil temp was 275 on the last run. engine and transmission temps were not an issue. Previously I was not able to run all sessions due to oil temp.
#87
Streets of Willow is pretty technical small track so not having big straight (high air flow) could be a factor. I guess we need a better oil cooler regardless.
#88
As it seems, the real solution will be primarily a better oil cooler or, the combination of the radiator + oil cooler.
#89
#90
275 is still very high for oil temps, particularly considering that you were staying in 3rd and 4th gears only. Had you used 2nd and 3rd, most likely your oil temps would be considerably higher.
#91
#92
#93
check with Ben@WeaponX
#94
I see you did the DEI Titanium wrap on the pipes. It helped me also. DEI just came out with a Catalytic converter shield and oil line sheath just for the C7. Even knocking out the heat coming off the converter not soaking into the lines or the cooler helped me tremendously.
It works really well and I can take off and on easliy. It's flexible and held on with stainless ties they give you in the kit.
It goes on the cat itself and not around the cooler to the cooler can do it's job but not get the heat soak from the cat.
#95
I am going to revive this thread as it's a very good temperature management thread. I just recently did:
DEI exhaust wrap around my transmission
DEI cat shield
2017 z06 front brake ducts
Removed all insulating/plastic covers from engine
My car is a 570 rwhp procharged z51, see picture on left (before removing engine covers) no other power or cooling mods.
90 degree ambient. EOT got to 300 as ECT got to 260. I had to short shift at 6000 rpm to keep from overheating. Also had to take it easy for about a lap every 5th lap or so to decrease temps down to 235-240. I don't think the cat shield did absolutely anything. However the pipe wrap around the transmission seems to have done way more than expected. As long as I didn't redline 3rd, my transmission never got above 220. Prior to this, it matched EOT and ECT (in terms of % of max).
Here is a video of my fast lap. Ambient was 90 degrees. Video starts 3rd lap in session, ECT started video at 220 and ended video at 250. There's no EOT datalogs but it was at 300 anytime ECT was 250+. IAT goes from 120-140 on the 3 laps.
I think my next logical step is a radiator. I cannot install an oil cooler or secondary radiator in the grill without major modification due to position of the massive horizontal procharger intercooler.
DEI cat shield
#96
Subscribed
