Exhaust install?
Old May 15, 2015 | 09:37 PM
SharkGrayStingray's Avatar
SharkGrayStingray
Originally Posted by Greg00Coupe
Shark grey.......thanks. You are right I do need a complete original exhaust system, which I have. My car was a beta for Corsa and they asked if they could cut up the stock exhaust for whatever research they do. I said sure as long as I get a new one which they did. Never asked but in the fall of 13 they went to a local dealer and ordered a new C7 exhaust. I would not even think it was available. I have the center pipe too and expect this reinstall to be piece of cake since my buddy has a lift.
I've done a lot of work on a C5, did not have my C6 long enough to work on it...... but frankly have not been under the C7 that much. Corsa did all the install, worked with a local tuner and turned the car back over to me.
it should be an easy swap, especially with a lift. I did mine in a few hours by myself on jack stands...
Old May 16, 2015 | 08:54 AM
Busa Dave's Avatar
Busa Dave
Just get a Borla--Bolt on--EASY... You can also put it back to stock if needed--EASY.
Mine runs Borla.
Make sure to disconnect the battery prior to doing any work. Actuators will need to be recalibrated if not. May throw a code.
Old May 17, 2015 | 01:05 AM
Good info on a catback install. Thanks.
