No lift shift
Old May 25, 2015 | 08:46 PM
BJ67's Avatar
BJ67
Default No lift shift
Does anyone know if all 7 speed C7's have the no lift shift technology or do you have to have a Z51 or Z06 to have this feature? I have a base 1lt 7 speed with NPP only.
And if it is in all 7 speed manual cars, how is it activated when I decide to experiment with it.
Old May 25, 2015 | 08:48 PM
GTB/ZR-1's Avatar
GTB/ZR-1
All--power-shift away!
Old May 25, 2015 | 09:56 PM
ziominix's Avatar
ziominix
No "activation" necessary. I believe past 6000 rpm with your foot to the floor it will be active. I've played with it a few times. It helped me achieve my personal best 0-60 of 4.1. Still room for improvement!
Old May 26, 2015 | 01:50 AM
CDH76's Avatar
CDH76
Are you referring to just launch control or are you saying I can rip through gears with out lifting throttle and it will not destroy my clutch? I knew about launch control but never heard you can just not lift??
Old May 26, 2015 | 07:16 AM
VThokies's Avatar
VThokies
I'm fairly certain it even works below 6000 rpm. I remember testing it at about 5000rpm one time. I shifted a little slow on purpose, and it held the rpm.
Old May 26, 2015 | 08:02 AM
BJ67's Avatar
BJ67
forget launch control, no lift shift has no bearing on the clutch either. Just keep it to the boards and at redline stab the clutch and shift.
Old May 26, 2015 | 09:39 AM
LT1_E85_Corvette's Avatar
LT1_E85_Corvette
oh yeah, it works awesome actually .
Old May 26, 2015 | 09:24 PM
BJ67's Avatar
BJ67
Thank you guys for sharing your knowledge, it really helps.
Old May 27, 2015 | 01:54 AM
CDH76's Avatar
CDH76
Where did you find this information out? I am just curious thanks.
Old May 27, 2015 | 10:35 AM
BJ67's Avatar
BJ67
What information are you referring to?
Old May 27, 2015 | 08:37 PM
BJ67's Avatar
BJ67
So you held the pedal to the floor, shifted at 5000 rpm and the rpm stayed at 5000 rpm while you pushed in the clutch and shifted to the next gear?
Old May 27, 2015 | 09:00 PM
CDH76's Avatar
CDH76
Sorry I wasn't clear. I was asking the people that stated you can shift through gears without lifting. I was curious where they found this information out. I knew about the launch control as I have done it before but I was not aware you could shift with out lifting the pedal. Just curious where they found this information.
Old May 27, 2015 | 09:32 PM
BJ67's Avatar
BJ67
I do not think its listed anywhere. I first heard it thru Cadillac. There performance cts-v 6 speed manuals have no lift shift. Then I heard the C7 7 speed manuals had it. But if you have never power shifted a manual trans, I wouldn't try it. Your better off just speed shifting
Old May 27, 2015 | 10:22 PM
Toilets's Avatar
Toilets
I thought a true no lift shift program holds the RPM right at the redline for a set period of time when up shifting? This car does NOT do that. At WOT, try clutching in only and you will see it will bounce off the limiter or in our case the RPMs will go till fuel cut off.
Old May 27, 2015 | 11:31 PM
Higgs Boson's Avatar
Higgs Boson
I will make it easy for you.
Old May 27, 2015 | 11:33 PM
Higgs Boson
You're doing it wrong. The ECM knows if you are moving the shifter (you know like the rev matching feature). If you just clutch in then you are not activating NLS. It's No Lift SHIFT, not No Lift PUSH THE CLUTCH IN.
Old May 27, 2015 | 11:37 PM
Higgs Boson
https://www.corvetteforum.com/forums...-shift-m7.html
To No lift shift
Old May 27, 2015 | 11:51 PM
11B250's Avatar
11B250
Higgs, you have me real confused. Are you telling me you don't even use the clutch when you do no lift shift?
because you most certainly use the clutch. it's no lift for the throttle, not the clutch. Again, I'm pretty sure I misunderstood you... lol
Old May 27, 2015 | 11:55 PM
11B250's Avatar
11B250
I've used the feature before and got my fastest 0-60 time (4.0) however I miss shifts alot (especially 2-3) with this. I can't see to time the shifting right. It has to do coordinating with my footwork.
Old May 28, 2015 | 12:03 AM
Higgs Boson
Yes you use the clutch to allow the shifter to move and leave the throttle pedal on the floor.
However, if you don't move the shifter, it isn't going to work, which was a reply to the guy who said he clutched in while WOT and hit the rev limiter. Of course it did, he didn't initiate any shift....
The best way to do this is to preload the shifter in the right direction. Begin applying light pressure to the shifter before it's time to shift. Clutch in and out as fast as you can and let the shifter go to the next gear. You don't even have to wrap your hand/fingers around the ****. Just let the shifter do it's thing. 99% of the time it will go into the next highest gear. That 1% of the time you have to train your brain to get out of the throttle and keep the clutch pedal in. Basically, if it feels a little off, abort, lol! Abort = clutch in, gas out.
