Tips on tow hook install C7
Old Jun 10, 2015 | 02:26 AM
Skylane765's Avatar
Skylane765
Supporting Vendor
Default Tips on tow hook install C7
Many calls come in on installing the front and rear tow hook. There is a build up of paint on the car receivers and it makes it hard to install the first time. We do make the shaft .010 smaller and sand the first part of the threads down, but you may need to sand some more and remember the front grill has to be pushed up some to get them in strait. GM did not design it right and its tough the first time installing.
The rear does not line up level with the car it slants down and also it is not square with the rear bumper IT IS IN LINE WITH CENTER LINE OF THE Corvette. The front is the same way. Wiggle it as you are installing the front one.
Old Jun 12, 2015 | 03:44 PM
Skylane765's Avatar
Skylane765
Supporting Vendor
For all the members that think they have different thread size, YOU DO NOT. You have the same as all other Corvettes it is M20 2.5 and they will all fit your car if you have the receivers. GM just has too much paint on them and did not chamfer the outside to install easier.
Old Jun 12, 2015 | 05:47 PM
baron95's Avatar
baron95
In case it is not obvious, I'd like to add that on the Z51 (vs the Z06) there is a section of the front grill that you remove to install the tow hook. Just lift it slightly and pull it out. If you try to install it without removing it, you will scratch the grill.
Old Jun 12, 2015 | 06:11 PM
Skylane765's Avatar
Skylane765
Supporting Vendor
Yes GM did a bad job of engineering the grills to line up with tow hook.
Old Jun 12, 2015 | 06:16 PM
Skylane765's Avatar
Skylane765
Supporting Vendor
We can walk you though install if you call anytime. 858 527 8727
Old Jun 5, 2016 | 11:46 AM
Damian M's Avatar
Damian M
Default Front tow hook
Hi Baron95,
I have 2015 C7 Z51, I can't locate the front tow hook, could I be missing something i.e. an attachment? Thank you for your help.
Damian
Old Jun 5, 2016 | 05:41 PM
TEXHAWK0's Avatar
TEXHAWK0
What year did GM add the receptical for the toe hook?
Old Jun 5, 2016 | 06:23 PM
Damian M's Avatar
Damian M
mine is a 2015, I bought it December 2014 so it had to be built I am guessing around July or August. From what I have learned, cars build post Jan. 2015 have the receptical. I know mine doesn't, bummer. Thanks for your reply.
Old Jun 5, 2016 | 06:29 PM
Damian M's Avatar
Damian M
I decided to go with the removable plate holder from Southern Car Parts for $180.00. It is expensive, but it leaves me with options to take it off easily when I want to. Thanks again for your help. Thank you MASSACHUSETTS!!
Regards,
Damian
Old Aug 10, 2017 | 09:36 PM
desmophile's Avatar
desmophile
Default rear tow hook receptacle
I have fussed with the little cover plate over the rear tow hook receptacle and can't get it off. Before I break it, I thought I would ask if someone had a tip for me. thanks paul
Old Aug 13, 2017 | 02:11 PM
BKorsaire's Avatar
BKorsaire
From: Chartres, with a cathedral of XII Century in the middle of the wheat fields FRANCE, la Belle et ses Iles
2017 Z have the receivers for the tow ?
Old Aug 13, 2017 | 02:54 PM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
For the poor slobs that DON'T have the ability to use these tow hooks, might I suggest this: https://www.corvetteforum.com/forums...post1593842194
I bought one of these for my 2014.
Elmer
Old Aug 13, 2017 | 03:07 PM
spearfish25's Avatar
spearfish25
Use a flat blade screw driver (larger blade the better) or a trim removal tool. You insert and pry along the groove on one side of the insert. It will pop right out.
Old Feb 26, 2024 | 07:05 PM
srskypuppy's Avatar
srskypuppy
The threaded hole for the tow hook is at an angle to the CL of the chassis, so to screw it in you need to wiggle the tow hook a bit to line up with the hole. You need more room to move than the small holes in the grill would allow. Instead, GM built in a 2" X 7" + - grill piece that snaps out. This gives plenty of room to install the tow hook! :-)
Old Mar 4, 2024 | 10:40 AM
MSGT-R's Avatar
MSGT-R
I did this for a C8 stuck in a snowy ditch (she rented it), There were two tow trucks and 6 guys trying to figure out how to hook it up
They were trying Subaru hooks and every type of device. My neighbor gave me a call, I drove out, popped the access panel and they
screwed in the tow hook.
The Tow Truck driver asked "Who the hell are you, and where did you come from? Too funny!
Old Mar 5, 2024 | 04:01 PM
Bill Dearborn's Avatar
Bill Dearborn
There isn't any section of the Z06/GS grille that snaps out. When screwed into the mount all the way the front tow hook will still move around enough the horizontal piece of the grille above the tow hook will break if you use the tow hook a lot. I used to use my tow hook to winch my car onto the trailer and found out the grille would break.
Bill
Old Mar 6, 2024 | 06:15 AM
curtis k taing's Avatar
curtis k taing
Cruising
thanks for the tow hook installation video. it really helps.
Old Mar 6, 2024 | 04:13 PM
joeone19's Avatar
joeone19
Front Tow Hook - GM (85513591)
Genuine OEM GM Parts & Accessories - 85513591
$103.34
Old Mar 12, 2024 | 07:26 PM
UpNorthC7's Avatar
UpNorthC7
I was all ready to order a tow hook, when I read in a couple of threads that early 2014's didn't have an insert. Upon further review I see a nice round blank spot behind the grill where I assume the insert would be. Build date was 10/17/2013 so that information is correct. Guess I'll be ordering a V-Bridle strap instead. Thanks to the forum members for pointing out those little things.
To Tips on tow hook install C7
