C7 A/C Fan Issue
Old Jun 22, 2015 | 08:32 PM
hansesm's Avatar
hansesm
Default C7 A/C Fan Issue
My 2014 Coupe A/C fan is running non-stop when the A/C is turned on. The fan stops immediately when the A/C is turned off. My local Chevy dealer states "it's normal". But I clearly remember not running all the time.
Am I crazy or not?
Noisy is Texas
Old Jun 22, 2015 | 09:01 PM
bob guzzy's Avatar
bob guzzy
Of course it runs when the AC is on, if it didn't your car would over heat as soon as the AC was on a few minutes.
Old Jun 22, 2015 | 09:20 PM
BJ67's Avatar
BJ67
Am I crazy or not?
Noisy is Texas
Fan runs all the time a/c on or off. But you can turn the fan on any speed you want including off anytime you want
Old Jun 22, 2015 | 09:23 PM
BJ67's Avatar
BJ67
Am I crazy or not?
Noisy is Texas
Are you talking about the fan inside the car or outside in back of the radiator.
Old Jun 23, 2015 | 09:42 AM
rothchilds's Avatar
rothchilds
I assume the radiator fan is what he is saying. Mine runs all the time whenever air conditioner is on.
Old Jun 23, 2015 | 10:04 AM
xp800's Avatar
xp800
Both my 2014 and now my 2015 do the same thing as the OP. It's normal.
The car will also run the AC under certain conditions by default mostly in humid conditions.
To disable this, you need to disable Auto Defog in the vehicle settings. Then only AC when button pressed...
Old Jun 23, 2015 | 10:25 AM
NSC5's Avatar
NSC5
If you are talking about the engine cooling fan then yes it is normal and has been for a very long time across models. When the AC is engaged and the compressor is running then the engine compartment fan has to run to bring air across the condenser or the AC will not cool and the compressor head pressure will quickly go excessive. Like your home AC system it is not some magical source of cold air but is instead a heat transfer system transferring heat from inside the cabin to outside and that outside rejector of heat (the condenser) must have air flow across it.
Old Jun 25, 2015 | 08:52 PM
hansesm's Avatar
hansesm
Default But....
Is it loud enough to hear inside the car? Just seems very loud
Thanks for the quick responses
To C7 A/C Fan Issue
