Catch Can questions
Old Aug 7, 2015 | 08:04 AM
grandpawmoses's Avatar
grandpawmoses
Default Catch Can questions
I'm wanting to install a catch can on my Z51 but need help deciding which one I want. The UPR has a petcock for draining but costs about $350. The Elite E2 is only about $165 (but is a little more trouble to empty).
Other than that, how complete are the kits? I mean are any clamps, fittings, or valves not included with either?
Is either kit reversible (no original hoses cannibalized)?
Because of price, I'm leaning toward the Elite E2 and drill & tap for a petcock. They offer options for different hoses and hose connections. Which is preferred?
Thanks in advance.
Old Aug 7, 2015 | 11:05 AM
bob guzzy's Avatar
bob guzzy
The new model elite does have a drain if I were to buy mine again I would buy the same elite I have only with a drain.
I have no problem draining mine I run the bolt out of the holder then turn the bottom off the can.
I have mine mounted to the left frame rail where the ground strap bolts are located.
Old Aug 7, 2015 | 11:17 AM
BJ67's Avatar
BJ67
The elite engineering basic unit in black is not noticeable, the standard fittings and hoses look like OE. Just remove the existing loop hose and save it, no cutting or butchery. Put back to stock and no one will ever know. Everything needed is with the unit. Yes you will have to unscrew the lower holding tank to empty but its easy. The quality and machining and the finish are top notch.
Old Aug 7, 2015 | 02:09 PM
meyerweb's Avatar
meyerweb
I have the Elite e2 and I don't find emptying it to be at all difficult. It's maybe 5 minutes to undo the mounting bracket, unscrew the cap, pour out the muck, and reverse. I think trying to get something under the cup and reaching in to open the petcock would be just as hard.
Old Aug 7, 2015 | 05:55 PM
grandpawmoses
You're probably right about the petcock. Did you opt for the "clean" side option? I found out that my good price was without that option. Seems that for either brand it's about $350. The Elite website ordering page confused me with some of the "options". Options like check valves, bracket types, single/dual outlets, hose barbs. Any help with that would be appreciated.
Old Aug 7, 2015 | 07:48 PM
BooSSted's Avatar
BooSSted
My elite is a pain in the a** to get off. Maybe I'm putting it on too tight.
Old Aug 7, 2015 | 10:41 PM
meyerweb's Avatar
meyerweb
I have a wet sump engine, so no need for the clean side. If I had a Z51, I probably would have gotten that. Cheap insurance in the long run.
If you're installing on a stock engine, you don't need check valves. The standard bracket comes with the can and works fine -- you don't need anything else. The stock hose barbs are fine, too. They're brass, so you can update to the nickel plated or AN fittings if you like the look, but the brass ones work fine.
Single or dual outlets is a little more complicated. I'm not convinced the dual outlet is necessary at all. If it is useful, it's really only at full throttle. You might want to read the appendix here for a more detailed description: http://netwelding.com/Catch_Can.pdf
Their web page doesn't seem to make it easy to find all the available options. I have an elite e2, but with a single exit and no clean side. I didn't see that on their website just now. I emailed them with some questions, and got just what I wanted.
Old Aug 8, 2015 | 12:00 AM
tblu92's Avatar
tblu92
St. Jude Donor '13-'14-'15
I have been using UPR for many years on all models of newer corvettes--Yes it is more $$ but the fitment and ease of installation is very simple and every component fits perfectly-- As far as how it works on every car I used it on the intake manifold was bone
dry---You get what you pay for---To me peace of mind that I'll never have an oil ingestion issue ever again
Old Aug 8, 2015 | 10:10 AM
Horsefly's Avatar
Horsefly
Default do a search for.......
RX Performance and check their catch can out. There is even a 3rd party review that is a pretty good read also.
I installed one of their cans over a year ago and it came with all herdware needed except for a mounting bolt. Did the clean side seperator also and made it look like a factory install by using existing hose execpt for a small 4 in. section.
Shout back via pm if you want to know more.
Old Aug 8, 2015 | 01:22 PM
davekp78's Avatar
davekp78
C1 of Year Finalist (stock) 2019
2016 C1 of the Year Finalist
2015 C2 of the Year Finalist
The base UPR is only $110. Beautifully made.
Old Aug 10, 2015 | 01:16 PM
COSPEED's Avatar
COSPEED
St. Jude Donor '10
You really want one that traps all the oil. Read this as there is so much disparity between cans that actual trap all (very few) and those that let most of the oil and other garbage still get past. ALL cans will catch oil, but with a DI engine you dont want ANY getting past. This test was performed over several months and thousands of miles. Lots of high quality looking cans out there, but very few that actual trap more than 20-40%:
I’ve had a UPR catch can on my 5.0 since last summer. It catches a lot, especially in the cold months. But I’ll get right to my test. I added an RX can inline after my UPR can to see if the UPR was missing anything. And if it was allowing some to pass through, was it enough for the RX to catch anything? I don’t drive a lot of miles regularly since my F150 is not a daily driver, so my results will take some time. This thread is to document how I set it up and what I catch over time.
I installed the RX can just as the directions explained, but I routed the hoses differently. I left my UPR can right where it’s been for months, but rerouted one hose. I left the hose from the passenger side of the engine to the inlet of the UPR can. Then a new hose from UPR can outlet, routed to the inlet of the RX can. The RX outlet hose goes back to the engine. The PCV exhaust now flows from the engine, through the UPR, then through the RX, and finally back up to the engine intake.
Before installing everything for the test, I cleaned the UPR can thoroughly. The bottom of the can (inside) was covered with a thin layer of stiff sludge that I could only clean out using gas. I’m glad that was caught, along with the ounces of oil, water, etc, over the months I’ve been emptying it. But I was surprised at the outlet hose from the UPR can. It was wet with oil. Obviously some was getting through the can and back to my intake. I’ve never let the can get close to half full before emptying it. Nearly every time I’ve emptied it, there was 1/4“ or less in the bottom. I’m noting this in case someone thinks I left the UPR get overfilled and it flowed through. Nevertheless, I started this test after cleaning everything for a fresh start.
I plan to leave this setup on for a thousand miles or so, and report my findings from each can.
1st picture: UPR*can as it was originally installed.
2nd:*CleanUPR can.
3rd: RX can installed. The hose in the top center of the can is the inlet. The outlet hose on the right has a check valve.
4th:*Engine outlet to UPR inlet on left of can. UPR outlet on right side of can routed around (smaller hose) to the RX inlet. You can also see the other smaller hose coming back up from the RX can and ending at the intake on the engine.
Report 2:
I thought I'd add a post to keep this thread alive since it is taking me awhile to get enough miles on the truck for valid results. Now that spring weather is finally arriving, I haven't been putting as many miles on it since I'm busy. But I have around 600 miles on the test set up so far. I emptied the cans recently and recorded the volumes to date. I'd like to wait until I get to 1000 miles before posting the results from the test, but I'll give some preliminary feedback.
- Emptying process -*
First the UPR. I'm used to emptying the UPR can regularly, so it's not a big deal to unscrew, guide the can out from between the hoses, pour it out, guide it back in between the hoses, get it lined up carefully (so I don't cross thread the soft aluminum) and screw it back up snug. All that takes less than a few minutes so it's rather easy.
Now the RX can. Raise the hood, hold an empty water bottle under the drain tube, open the valve, close the valve, close the hood. I kid you not, it takes no more time than it took to read those steps. I knew it would be easy to empty, but it is ridiculously easy.
_ The weather so far -*
During the first week of the test we had winter weather, with some snow. Since then we have had mild weather. Temperatures are in the 50's and 60's most days.
- What they caught so far -
I won't share the amounts yet, but I'll give some info. The UPR can has caught a 'mostly oil with a bit of water' mixture so far. The RX can (in line after the UPR) has had just the opposite. It's collected mostly water or fuel, with some oil mixed in.
I emptied the UPR first, and I would estimate it has collected the normal amount compared to what it usually does I empty it. I was pleased that my set up with 2 cans didn't seem to change the normal flow and collection I was used to seeing with just the UPR can. When I was about the turn the valve to empty the RX, I paused to a few seconds wondering if anything would come out. After all it was a new can that would need to get some oil/water coated on the inside before there would be enough to drip to the bottom (The UPR can had been in use for many months and although I cleaned the can I did not rinse off the filter material). Plus I wondered if the valve of the RX can protruded up into the can, and if it required some liquid to collect before there was enough to spill over that valve nipple and exit the can. Then I opened the valve and I had to smile when I had some liquid drain out. I thought all along that if it caught more than 10% of what the UPR was collecting, I would be surprised. It's still early in the test, and I would like to redo the test after reversing the order of the cans later, but I am surprised so far. I'm hoping to get more miles on the truck soon so I can wrap up this phase of the test.
Report 3:
1000 Miles of Testing Results
- The Weather*has been warmer lately. So the test began with sub freezing temperatures, and gradually increased through the 70's and topped off in the mid 80's yesterday. I couldn't have asked for a better range of temperatures for this test.
- What they caught*was astounding to me. UPR was first in line, with the RX after it to catch anything the UPR might miss.
The UPR stayed on track with what it has been accumulating for many months. Each time I emptied them, it had about the same amount. It's contents were mostly oil which smelled like used oil. It caught 17cc total which is just under 3 1/2 tsp.
The RX had more than the UPR each time I emptied them. It's contents were an oil/fuel/water type mix that had a much stronger odor. Not a fuel smell, but a sharper chemical smell compared to the odor of used oil. It caught a total of 67cc which is just over 13 1/2 tsp.
- Final totals:
UPR - 17cc
RX - 67cc
The RX can caught 4 times the amount the UPR can caught,*after*the UPR can removed what it could. I said from the beginning I would be surprised if the RX can could pull 10% of what the UPR caught, since it was second in line. If someone told me it would catch an equal amount I would have said BS. For it to catch 4 times what the UPR can caught is unreal.
Report 4:
The routing of cans has been reversed*so the second phase of the test is underway. I cleaned the cans and hoses so neither has an advantage. I also checked the inside of the hoses as I disassembled everything. The exit hose from the UPR was dripping with oil and it made a mess as I took it apart. The exit hose from the UPR was clean and dry. It still looked new. That is what prompted me to clean all the hoses before starting this phase. Is the double can routing helping the second can*that*much, or is one can that much better. Time will tell again.
Report 5:
And now back to our regularly scheduled programming…
Phase 2 is almost complete now, thanks to some extra mileage for work. I'll report on that soon and begin phase 3.
As I said above, UPR shipped parts for me to do phase 3 of the test. I bought my UPR can in June, and they changed the can slightly since then. The new diffuser/extension will only fit cans made after that, so they shipped a full new kit to test. Thank you UPR for helping with this, and for your input in this thread.*
After shipping the kit, Joe@UPR asked me to remove the mesh from the exit side of my existing can for the remainder of phase 2, and to remove the mesh from the exit side of the new can before starting phase 3. I removed it from both (phase 2 was half way done when I removed it from the existing can). When I was removing the mesh from the short side of the new can (in preparation for phase 3), I realized the diffuser was assembled backwards. For our 5.0 F150's the long side of the diffuser must be on the passenger side of the can when installed. I disassembled, removed the mesh packed up in the can top on the exit/passenger side, and reassembled the can with diffuser. For anyone who might have received their cans assembled by UPR, you should check to see if it was assembled correctly before installing. (EDIT: Joe notes below they assemble the cans for shipping, and all cans should be assembled for your own installation needs) I also had a small piece of the stainless steel mesh (1/8") drop out when I was doing that. I wasn't thrilled with that so I unrolled, and lightly tapped the mesh in case there were any other loose pieces, but there weren't. A quick note on the UPR kit... it is much improved since I bought mine. The hoses are pre cut to the proper lengths, the elbow fittings are nickel rather than plastic, and they include Ford OEM snap on valve cover and intake fittings.
More to come soon!
Report 6:
Test Results
-*I'll summarize*the test to date. The first phase was to test the UPR vs the RX catch cans on a 5.0, both base models, with the UPR first in line and RX installed to catch anything the UPR missed. Those first phase results were: UPR - 17cc, RX - 67cc. The 'first in line' UPR caught 20% of the total volume. See post 37 in this thread for more details. The cans were cleaned and reinstalled in reverse order for phase 2, RX first and then UPR.
Phase 2 Test Results
- The Weather*has been average northern Ohio spring weather. Some rain, fog, cool nights, warm and hot days.
-*Driving*has been about the same through both phases. I good mix of rural roads, some small towns, highways, and approximately 40% of the miles on interstates at 65 - 80mph. Mostly average style driving, with a few very heavy accelerations mixed in. A little heavy hauling, and no towing.
- What they caught*this time might have been predicted by some (after the results of phase 1). RX was first in line, with the UPR after it to catch anything the RX might miss.
The combined volume of gunk was half of that caught in the first phase. The first phase had some cold weather which accounted for more water in the mix and the higher volume.
The contents from the RX can was mostly oil/fuel, and had a strong chemical/solvent smell again. It caught 35.5cc total which is approximately 7 1/8 tsp.
The UPR can caught about the same mix of oil/fuel, but didn't smell quite as strong. Halfway through this phase, Joe@UPR asked me to remove the mesh on the exit side of the UPR can. I did that, but noticed no difference in what it was catching. But since it was second in line, and there was little to catch, that's understandable. The UPR can caught 1.75cc total which is approximately 1/3 tsp. With so little collecting this time, I monitored the contents of the UPR can but didn't empty it until the end of the test.
- Phase 2 Totals:
RX - 35.5cc
UPR - 1.75cc*
-*Other tidbits*include the 'first in line' RX can caught 95% of the total volume. The exit hoses were very clean from both cans. The last few tanks of gas have produced slightly higher than my normal MPGs, but it's too early to tell on that (more to follow after phase 3).
-Phase 3,*using the UPR can extension and diffuser, is underway. Details will follow.
Final Test Results
-*I'll summarize*the test phases. The first phase was to test the UPR vs the RX catch cans on a 5.0, both base models, with the UPR first in line and RX installed to catch anything the UPR missed. Those first phase results were: UPR - 17cc, RX - 67cc. The 'first in line' UPR caught 20% of the total volume. See post 37 in this thread for more details on phase 1. The cans were cleaned and reinstalled in reverse order for phase 2, RX first and then UPR. The second phase results were: RX - 35.50cc, UPR - 1.75cc. The 'first in line' RX caught 95% of the total volume. See post 143 for more details on phase 2.
Phase 3 Test Results
- This time the UPR can*was first in line as in phase 1, but it had the new can extension and diffuser added. It also had the mesh material removed from the exit side of the can.
- The Weather*has been average northern Ohio early summer weather. Some rain with warm and hot days.
-*Driving*has been a good mix of rural roads, some small towns, highways, and approximately 60% of the miles on interstates at 65 - 80mph. Mostly average style driving, some steep hill climbs, and some very heavy accelerations mixed in. A little heavy hauling again, and no towing. I'll add some more thoughts on driving and MPGs below.*
- What they caught*was a mixed bag. UPR was first in line, with the RX after it to catch anything the extended UPR might miss.
The combined volume of gunk was down from the last phase, again. I assume it is due to the warmer weather and maybe my engine is using less oil with more miles? Either way, my test looks at the percent each can catches, compared to the total caught for that phase, so the volume isn't critical.
The contents from the extended UPR can was mostly oil, and had a used oil smell. The UPR caught 14.75cc which is approximately 3 tsp.
The RX can caught a fuel/water/oil mix. It smelled much more harsh again. The RX can caught 16.00cc which is approximately 3 1/4 tsp.
- Phase 3 Totals:
UPR - 14.75cc (48%)
RX - 16.00cc (52%)
-*Other thoughts*on the results. The contents of each phase showed me the RX does a better job of removing more than oil. It always contained more water/fuel type liquids, while the UPR contained mostly oil. I don't know if it is due to the can design, the 'out front' mounting style of the RX, or both.
For anyone buying or thinking of upgrading their UPR can, I strongly recommend figuring out how to mount it out front, and would definitely add the valve that Joe@UPR is offering. I really think the 'out front' cooling effect will help it catch even more, and the valve would be worth the price for ease of emptying it. Having the RX can to compare to when emptying, the front mount and valve are no brainers.
As I said at the end of phase 2, my MPGs have increased slightly. I have done nothing different to my truck over the past year, other than adding the RX can to the UPR for this test. My driving style is very similar from tank to tank, I fill up at the same stations, etc. But since having both cans in series, and essentially removing 95% or more of the PCV byproducts, my MPGs have increased. Up to that point my lifetime MPGs were 17.5. Nearly every tank for the past year gave me the same results, 17.5. I would have some trips that would net 20 MPG, but the other short trips would always pull it back down for the same tank average - close to 17.5. My recent tank averages have all been over 18 MPG, with a few over 19, and as high as 19.5. My last tank included hauling approximately 1000 lbs of payload, through some long hills/mountains of PA, and I got 18.8 MPG. It could be the summer fuel mix combined with an engine that is broken in, but the timing is peculiar. Whatever the reason, I like it!
Now here is why you want dual outlets (like the E2 or their brand new line of E2-X cans, or our just released CoSpeed versions).
When ever you accelerate, the vacuum present in the intake manifold that the PCV system relies on to remove the damaging compounds from the crankcase drops to zero, so at this time crankcase pressure is allowed to build and it seeks the path of least resistance, and this is out the in. Or out the cleanside into your main intake air tube assy. bringing in oil with it. So, the E2 or others you run the second outlet to the coupler that attaches the TB to the intake tube, and that allows for suction to maintain evacuation on the crankcase at all times resulting in less contaminates being able to settle into the crankcase and accumulate in the oil accelerating wear. Then, the cleanside spearator replaces the oil fill cap and the OEM cleanside line so it will trap any oil that does start to make its way out the cleanside line.
You really do get what you pay for as this test above shows (anyone can perform this, and it is on-going right now showing the Moroso just as poor as the UPR in the test, and the MM and Mike Norris are next).
The New E2-X and the CoSpeed kits all have 1/4 turn drain valves for ease of emptying, a hose can be run from them to under the car so it is easy to do when changing oil, or simply place a cup under the drain (do NOT use a Solo cup or similar as the very efficient cans also catch water/unburnt fuel/sulfuric acid/etc. and will melt the plastic. Use a water bottle or other container resistant to gasoline.
Also, all 2014 and up GM engines already come with a oneway checkvalve in the valley barb assy, but it is a ball style and can get jammed if using forced induction, so the need for the external ones is critical as well.
Want to learn more about the LT1 dry and wet sump and the LT4 as far as issues? Click on my username, find more posts, and read a ton of good technical info for any with a new Stingray.
Old Aug 10, 2015 | 01:20 PM
COSPEED's Avatar
COSPEED
St. Jude Donor '10
One final thing, the genuine original RX systems are no longer available....another Company is having them made as cheap knock-offs in China and are no where near the quality the originals were. They got their web URL's and all so be aware of anything now being sold under the RX brand.
Old Aug 10, 2015 | 01:59 PM
xp800's Avatar
xp800
Very satisfied with my Elite E2 single outlet on my Z51. Easy to drain with no bracket loosening.
My updated review here:
https://www.corvetteforum.com/forums...15-z51-a8.html
Old Aug 10, 2015 | 03:08 PM
meyerweb's Avatar
meyerweb
Proof? RX is working directly with a couple of Z06 owners to develop a system for that car, in Florida, right here in America.
I was with you all the way until you started spreading these unsubstantiated rumors.
Old Aug 10, 2015 | 05:31 PM
davanz's Avatar
davanz
coSPEED2, can you give more information on this change in the RX cans? When did the design change and when did the new ones go on the market. If one is purchased from RX Speed Works in Sarasota which design will it be?
Old Aug 10, 2015 | 06:14 PM
meyerweb's Avatar
meyerweb
Originally Posted by sycraft
That was an OLD test, many changes have been made now. I will not bash other manufacturers openly , But I will praise products that Have worked for me. .
What's amusing is that while he bad mouths his competition, he provides no test results or other evidence that his product is any good.
Old Aug 10, 2015 | 07:03 PM
COSPEED's Avatar
COSPEED
St. Jude Donor '10
That was an OLD test, many changes have been made now. I will not bash other manufacturers openly , But I will praise products that Have worked for me. UPR has earned that praise, I have tried others too. Mightymouse is excellent as well, not to be name called by unscrupulous vendors. Look at the construction, nothing hidden, look for the tests and reviews out there, both good and bad, the internet is full of mis-information, just depends on what you are looking for. As far as RX, As far as I know, Tracy is still in FL. I have chosen what I feel works for my needs and will not be bullied into bashing other peoples products. Just be glad one is being used if you feel you need one. As my mods change, my choice of can will change too, as some are better than others in certain aspects important to me.
You can read the later posts on that test thread where Joe from UPR threatened RX that he would copy their can and mass produce and put RX out of business, then later he did copy it directly and advertised this on several forums, so yes, after the dismal results (even with UPR having the guy testing stop at the 1/2 way point and add modifications that did help slightly) so prior to that he was arguing that "old" design was the best. If you want the links to his advertising that he copied the RX system we can provide that. So what your saying is you are happy with the RX copy UPR now sells? RX was the pioneer on all of these improvements and spent years of R&D and $ to develop these, and not only did UPR copy them, so did RXspeedworks selling the cheap Chinese knock-offs, so RX has stopped or they would still be the #1 most effective. Glad we have what we are releasing and the Elite Engineering's latest now, and have the original, genuine RX people endorsing due to this. Hope they can get their Patent enforced and correct what has happened, but until then, RXspeedworks is NOT the true RX Performance Products. LLC. The knock off sellers have their URL and everything hijacked.
No, you will not have the "genuine deal". They are the knock off cheap pressed together and plastic China knock-offs. RX always was 100% made in the USA quality. And they do not have the knowledge for any meaningful tech support.
Correct. These test's are what show the real data all should study. Sad RX had us stop advertising their's. But they have endorsed the Elite E2-X and the new CoSpeed's own, so the C7 Z06 solution is available (and would expect those with no ethics that copy others will copy RX's unique LT4 solution when they get there hands on it).
RX Performance Products, LLC (no affiliation to speedworks, Extreme auto, etc.) is still alive and well and can be contacted to verify any of this. For those that want to see how UPR dealt with their customer taking RX up on the "RX Challenge" once he saw the results, here is part of what Joe had emailed to the owners:
I would appreciate you not referencing my parts and business. I saw your post about UPR cans on need for speed. I am not happy to say the least about your tactics and forcing product on people.------------- You call our can a pull through, so how can you get caught with your double talk about our cans will fill up and hurt the engine. Pretty interesting since we have an ecoboost that we let the cans overfill and all it did was pull the little bit of oil at the top off the very same as no catch can at all. Oh wait, it must work so good that it magically sucks the oil pan clean.
If you continue to use and show my products as being faulty or not as good as yours I will have your can manufactured in billet to be a quality item ! Them proceed to sell all your dealers with my endless source of supplies.
Keep in mind, RX did NOT start that test, it was a UPR customer and UPR was behind the test all the way until it backfired. And I don't see them having a LT4 solution until they can get and copy RX on it as well.
So, those that feel this is the type of person to do business with, by all means us him.....but I see this as un-ethical in the highest degree.
Enough of this drama, lets get back to facts, data, technical discussions here. RX wanted the record set straight.
Group hug and put this to rest!
To Catch Can questions
Old Aug 10, 2015 | 08:24 PM
COSPEED's Avatar
COSPEED
St. Jude Donor '10
Quote from UPR on another GM forum:
We were selling another companies catch can through UPR and after this test we decided to develop a system that incorporated the Best of the RX
Old Aug 10, 2015 | 08:33 PM
Roadrogue's Avatar
Roadrogue
I have had both the only similarity as that they are round, internally different and built different. l Don't want to get into pissing match, I have lots of **** if needed. Just saying if RX had merely promoted their can and not bash others , he would have been better off. I am good, my stuff works and performs great. Keep the internal vendor to vendor out of the publics eyes.
Why? The info is interesting and helpful for new owners in learning of issues and vendor tactics.
Old Aug 10, 2015 | 09:19 PM
COSPEED's Avatar
COSPEED
St. Jude Donor '10
I have shared the proof with Sycraft so he can search for himself and see the timelines on all of this and we are both editing out the drama.
Somehow he was misinformed it appears but we have no beef with him as long as he post's accurate info.
Thanks and lets get back to design and technical discussions on catch cans and how some work very well, and some not worth a dang...no matter what they look like as many of the least effective are excellent quality in construction and appearance.
