I have the A8. Has anyone with the A8 trans replaced the 2.41 rear with a 7 speed 3:42 gear ? Performance should be spectacular never mind adding a 3500-4000 stall. Maybe I'm wrong since I do not see any doing these. Also, if I did add a GM (bought from them) 3:42 rear.... Would that void my cars warranty?
I posted the same question a number of months ago. I don't think anyone made that mod.
I have the AFM disabled with the Trifecta tune and found the car cruises in Touring mode at 1800 rpm at 70 mph in 7th gear and at 2200 rpm at 70 mph in Sport mode in 6th gear. I can cruise at 1400 rpm at 70 mph if I shift to M, which keeps the car in 8th gear, so long as I don't accelerate hardly at all.
Since disabling the AFM, I can't really get into the throttle more than 1/4 safely on the streets or even the freeway.
Going from a 2.41 to a 3.42 would be impressive, nearly a 30% increase in gearing. Can you say “light them up?!”
Right from the get go, when I was ordering my 2014 with the A6, I wondered why couldn’t you get the A6 Z51 gears which were 2.73? Can’t see why not, they passed emissions with the Z51 package and obviously GM considers them to be sufficiently durable. Nothing hard to do on the assembly line. Don
The A8 transmission gears are already very steep, the car gets up into the power band quickly.
Your car won't make any more power with new gears, and it won't weigh any less. It will probably not be any faster at all, it'll just shift more often (and A8's already shift a lot).
Rear end gears are kinda like ignition timing in the way that if your car needs it, it'll make a HUGE difference. But if your car already has enough, adding more really won't help at all.
Curious how much power you're making or plan to make and what tire running/run?
At stock 6600 rpm limit and 28" tire, 5th gear would be limited to 126mph. Though 6th is actually 1:1, it wouldn't be optimized for 1/4. Unless you're making some serious power and then the gearing wouldn't be as beneficial I'm afraid. The starting line overall ratio with a8, 3.42 gears and 28" tire would not be much steeper than a6, 3.42 and 25.5" tire which some c6s ran iirc.
On a side note a gtr has a 4.06 first gear and 3.70 rear gear, which is only slightly less overall than a 4.56 and 3.42 combo.
The gtr runs an almost 28" tall tire, so it's not steeper than an a8 with 3.42...I'm aware it's heavier and awd, but I assume he's talking about maximizing track times on a sticky tire being he mentioned a higher stall converter as well and isn't concerned about hooking up on the street with street tires. Atleast I know that wasn't the case when my uncle had 4.88s in his '69 camaro lol
good point about the tire height, I didn't consider that.
I run 5.83's in my cobalt and it is 3000 lbs with a 550 hp NA 327 at 8000 RPMs....
