Swapping Radiator for Dewitt’s, got a problem
It’s pretty obvious there is a leak, but all the hoses are on, reseated the clamps twice. The grommet I used fits the tank really snug. I have tightened it much more then I probably should have thinking that was the problem.
I’m considering pressuring the system using an air regulator to provide about 20psi from my compressor, with a soapy solution in a squirt bottle, might be the best way to find the leak.
Anyone have any ideas, or similar experience?
Mine is a 2015 Z06, but the service manuals are not available yet. I would think the 2014 Stingray would have the same coolant routing schematics and procedures being the same radiator is used.
If someone has the Service manual for their 2014 would you mind posting a pic of the hose routing if there is one?
Thanks in advance
Thanks in advance
I wouldn't put 20 psi to it either.
I think starting with 10 is a good idea, thanks for posting.
Now, if I could only find that dang regulator, any other time I'd be tripping over it.
The large lower hose was leaking, so I repositioned the clamp to no avail.
So I get my digital calipers out and begin measuring everything.
It turns out the new radiator hose neck's are smaller diameters then the original.
Here are the sizes
The large upper and lower OEM is 1.350"
The smaller lower clip-on OEM is .638
The smaller upper clip-on OEM is .375
(measurements are with in +- .005 difficulty getting calipers in there.)
The large upper and lower Dewitt's is 1.250" (0.100 smaller)
The smaller lower clip-on Dewitt's is .611 (0.020 smaller)
The smaller upper clip-on Dewitt's is .375 (same)
OEM neck
OEM Clip-on
DeWitt's neck
DeWitt's Clip-on
I will call Dewitt's tomorrow and see what they say.
