C7 Trinity remove rev limiter
Old Aug 17, 2015 | 08:07 AM
Meerology's Avatar
Meerology
4th Gear
Default C7 Trinity remove rev limiter
Hi all,
I just got my Trinity and ive been trying and searching for hours but no use.
How can you remove the rev limiter on a 2014 Corvette C7 A6?
Thanks in advance
Old Aug 17, 2015 | 08:45 AM
10mm_'s Avatar
10mm_
St. Jude Donor '15
Do you want to remove it or raise it?
Not sure why anybody would want to completely remove a rev limiter...
Old Aug 17, 2015 | 09:05 AM
Meerology's Avatar
Meerology
4th Gear
Remove it so it bounces at redline XD
If not raising it as close to redline as possible.
Crazy I know...
Old Aug 17, 2015 | 09:51 AM
10mm_'s Avatar
10mm_
St. Jude Donor '15
Crazy I know...
Are you saying your car doesn't rev to 6600?
Old Aug 17, 2015 | 10:17 AM
Mike@DiabloSport's Avatar
Mike@DiabloSport
Supporting Vendor
We allow you to raise the rev limiter, after you select the tune choose the option to modify the tune, then go to rev and speed limits, select rev in D or rev in p/n, and you can ad I think up to 600 rpm over stock then load the tune with those changes.
Old Aug 17, 2015 | 11:44 AM
Meerology's Avatar
Meerology
4th Gear
No just to 4000
I selected a tune and chose modify parameters. I only found speed limit and something similar to rev in D. Couldn't find Rev in P/N.
I cant totally remove the rev limiter in P/N?
Old Aug 17, 2015 | 11:46 AM
Mike@DiabloSport
Supporting Vendor
No, we dont allow for removing it, and I have to say, the neutral limiter is there for a reason
To C7 Trinity remove rev limiter
