C7 LT1 Motor Limit?
Old Oct 11, 2017 | 12:04 AM
  #141
WarHammer619's Avatar
WarHammer619
I would love some opinions from the people on this thread.
I Have a 2017 Grand Sport with an
A&A Supercharger Ti-V3
3.8 pulley
Single nozzle of meth
ARH w/hi flow cats
ARH xpipe
I see Cunningham has a drop in piston and rod combo. Do you all think that with a proper camshaft, LT4 injectors and pump and a dual nozzle of meth I can pass the 800 whp level? or is the head unit going to be the limiting factor? Also should I do e85 instead of meth? Thank you all for such great imput.
Robert
Old Oct 11, 2017 | 03:00 AM
  #142
FYREANT's Avatar
FYREANT
I'm Batman..
Pro Mechanic
3.8 pulley
ARH w/hi flow cats
ARH xpipe
Robert
With the mods you suggested (pistons, rods, cam injectors, HPFP pump, dual meth) you can surpass 800. You'll also need a 3.47" pulley for the top and an 8.65" pulley for the crank. Will take you to the limit of that head unit and even over spin it a bit. Im making 828 with all that minus the rods..
Old Oct 11, 2017 | 07:36 AM
  #143
blown81bu's Avatar
blown81bu
Im at 141 mph in the 1/4 mile
Never been on a dyno
Stock engine LT1
D1 procharger,meth, headers
I think i can go 143 ish next time out in a few weeks
Old Oct 11, 2017 | 09:13 PM
  #144
WarHammer619
Thank you for the response. Do you think pulling the Meth and doing all E85 is a better option? It has been brought up that Meth can be cylinder biased. Any thoughts?
Old Oct 11, 2017 | 09:31 PM
  #145
FYREANT's Avatar
FYREANT
I'm Batman..
Pro Mechanic
I would keep the meth and still plan on E85. Remember that unless you upgrade the low side you will run out of fuel at around e40-E50. Cylinder biased? Maybe. But not as much as everyone makes it out to be. Its not cylinder 1 is getting 90% of it and starving the rest. If it was an issue, more meth cars would blow up..
Old Oct 11, 2017 | 09:43 PM
  #146
spinkick's Avatar
spinkick
Id like a build where you can continue to. Do laps around a track over and over again, like the GS can now without most of the overheating worries. Magnusson? 650 wheel horsepower, maybe headers and intake?
Old Oct 12, 2017 | 11:44 AM
  #147
WarHammer619
That definitely makes sense. I think the E85 since it is everywhere around here is going to help. I am going to bump up to the LT4 pump when I do the rest. that should hopefully be sufficient at the 800whp mark.
Old Oct 12, 2017 | 01:01 PM
  #148
FYREANT's Avatar
FYREANT
I'm Batman..
Pro Mechanic
With a cam that has a 32% lobe and the LT4 HPFP, make sure you use the correct lashcap as many shops get this wrong and end up blowing the HPFP..
Old Oct 16, 2017 | 06:43 PM
  #149
officermartinez's Avatar
officermartinez
Guess you can add these to the list. Just got the word from my builder after everything was thoroughly inspected.. My heads and "former" TS&P VVT-1 camshaft were fubar'd. Ouch.
199-LT1GM - Texas Speed and Performance Precision Race Components 2014+ 6.2L Corvette Ported Cylinder Heads
Originally Posted by officermartinez
I purchased TS&P darton sleeved 416 LT1 short block. With several different offerings on their short block, I opted for the following:
186-U17171 - Callies Ultra Billet 6.125' Ibeam
Connecting Rod Set, 4330V Forged
76-00106 - Joe Gibbs Break-In Oil, 15w-50
wt., 21 Quarts
186-5UO31T-MG - Callies Magnum 4.00"
Stroke Gen 5 LT1 Crankshaft, Dry Sump
4340 Forged
46-234-5802 - ARP Main Stud Kit, 2014+
LT1 6.2L
28-12638926 - 2014+ LT1 OIL RESTIRCTOR
PLUG (BARBELL)
28-19329617 - 2014+ LT1 BARE ENGINE
BLOCK
28-12656770 - LT1 Piston Oil Squirter
2014+ 8 required
28-11546665 - 2014+ LT1 ENGINE BLOCK
PLUG
28-1453658 - GM Transmission Dowel Pins
168-930228070 - Mahle Motorsports LT1
Gen 5 Piston Set, 416ci, 4.070bore,
4.000stroke, 6.125rod, 1.105c/h, .927pin, -22ccvol,
412g, 10.0c/r, 2618 Forged
168-6457147 - Mahle Upgraded HD Wrist
Pin for TSP Exclusive Piston Sets, Per Pin
25-TSPLT1VVT-3-10 - Texas Speed & Performance Gen
5 LT1 VVT-3 Camshaft w/ +32% Fuel Lobe: 235/239,
.645"/.635", 116 LSA, 112 ICL
333-25-315717 - LT Camshaft Core 5150
28-SDCrateSB - GM Engine Crate for Short-Block
Engine Assembly
28-SDCradle - GM LT Engine Cradle for Engine With
Oil Pan
My heads will be re-inspected and I will re-use those if all is
up to par. Texas Speed and Performance already did a
porting job on them.
Old Oct 17, 2017 | 07:09 PM
  #150
officermartinez
I took 6-7 pictures today of what's left of my former setup (REST IN PIECES). Just brutal! ..and wouldn't ya know it, I needed more parts. The limit of our LT1 was pushed really hard. Now that we are into a building phase, I picked up these parts today at TS&P, Chevrolet Dealership and Corvette Mods:
28-12623368 - 2014+ LT1 6.2 Camshaft Phaser gear
25-0DEGPL - 0 Degree Phaser Limiter
28-12589016 - GM Camshaft Retainer Plate (Require QTY:4 28-11561455 Bolts)
28-11561455 - GM Cam Retainer Plate Bolt (Countersunk)
28-12585546 - GM 58x Crankshaft Position Sensor
28-12660737 - LT1 Stingray Valley cover 2014+
28-12659937 - GM Gen 5 LT1/LT4 Oil Pump, Dry Sump
28-12630107 - LT1 Chain Dampner
46-234-4342 - ARP HEAD STUD KIT LT1 6.2 W/O CORNER BOLTS
LT1 RockerUpg: 347-2110 - Johnson Lifters Drop-In Hydraulic-Roller,
No Link Bar, .045" Taller Than LS7 Lifter, .035"
Recommended Pre-Load +-.010"
Qty: 02 - Chevrolet Corvette 2014+ Stage 1 front spitters
Qty: 01 - Chevrolet Corvette 2014+ Oil Pan
Qty: 02 - Chevrolet Corvette 2015+ LT4 Head Gaskets
Qty: 01 - P/N: 2700 MSD Atomic AirForce Intake Manifold LT1 Gen 5
I also shipped my ECS 2200 blower back to Paxton today. Hopefully everything is good to go with it. I still have to purchase a few more high ticket items but pretty much everything that needed to be replaced, has been replaced.
Old Oct 17, 2017 | 07:42 PM
  #151
FYREANT's Avatar
FYREANT
I'm Batman..
Pro Mechanic
Old Oct 17, 2017 | 08:32 PM
  #152
officermartinez
Here's the carnage.. LT1 motor limit.
Old Oct 17, 2017 | 08:40 PM
  #153
FYREANT's Avatar
FYREANT
I'm Batman..
Pro Mechanic
Ugghhh.... such graphic photos..
Old Oct 17, 2017 | 08:42 PM
  #154
blown81bu's Avatar
blown81bu
Who has the fastest MPH at track stock LT1 w power adder
No cams or touching stock LT1
I went 141 at atco dragway last year
Old Oct 17, 2017 | 11:32 PM
  #155
Nabush's Avatar
Nabush
How much boost / HP / TQ to obtain this result
Old Oct 17, 2017 | 11:49 PM
  #156
officermartinez
I had the dynograph posted here at one point. Over 1000 hp and can't remember the TQ. 22 #'s of boost. Tons of M1 meth. Wiseco / Vengeance Drop In Pistons. Stock crank and rods. TS&P cam and heads.
Old Oct 18, 2017 | 10:01 AM
  #157
John Micheal Henry's Avatar
John Micheal Henry
^^^ Ouch.. Good luck with the rebuild..
To C7 LT1 Motor Limit?
Old Oct 22, 2017 | 11:25 PM
  #158
LT1pwrd'94's Avatar
LT1pwrd'94
What’s the current status of your build?
Shortly after I messaged u on this post about checking yours out, I had a valve spring break at less than 1800 rpms on stock engine with 7190 miles on it.. Cold air intake, kooks longtubes, catted x-pipe, and tune are only mods.
I’ll be doing a tsp longblock build or at least rotating assembly if block is usable. So I’m even more interested in seeing yours now for sure.
Zach
Old Oct 22, 2017 | 11:36 PM
  #159
Nabush's Avatar
Nabush
Zach
Seriously, i'm thinking of replacing my stock springs since i want to go headers and intake.
I'm supposing since you have mods GM denies your warranty ? which years is your vette ? I have a 2017 GS and not very confident...
Old Oct 22, 2017 | 11:40 PM
  #160
FYREANT's Avatar
FYREANT
I'm Batman..
Pro Mechanic
Considering replacing your springs to do intake and headers? why?
I had intake, long tube headers, ported TB and a tune for over 25K before adding boost for another 25K. that's 50K miles on the motor on the stock springs before I pulled it and built it. The springs are fine with intake and headers..
