C7 LT1 Motor Limit?
On my way back home from my local post office, a guy and his little kid pulled up next to me at a stop light. He gave his thumbs up of approval and I lightly blipped the throttle. He and his kid were both grinning from ear to ear. The light turned green as I drove normally off the line. At about 30-35 mph, I gave it a moderate amount of throttle. Without warning, BOOOOOM! Pop went the weasel. Chunks of my lower block littered the street.
That's where I am at right now. A lot of unknown data at the moment. Less than 36 hours later, I was on the phone with LME and Texas Speed and Performance. Since I knew my block was gone, I decided to go with a 416. I spoke with Bryan about my needs. I was very impressed with his attention to detail. However, after speaking to Derek, ultimately I decided to do a similar offering from Texas Speed and Performance.
I purchased TS&P darton sleeved 416 LT1 short block. With several different offerings on their short block, I opted for the following:
186-U17171 - Callies Ultra Billet 6.125' Ibeam
Connecting Rod Set, 4330V Forged
76-00106 - Joe Gibbs Break-In Oil, 15w-50
wt., 21 Quarts
186-5UO31T-MG - Callies Magnum 4.00"
Stroke Gen 5 LT1 Crankshaft, Dry Sump
4340 Forged
46-234-5802 - ARP Main Stud Kit, 2014+
LT1 6.2L
28-12638926 - 2014+ LT1 OIL RESTIRCTOR
PLUG (BARBELL)
28-19329617 - 2014+ LT1 BARE ENGINE
BLOCK
28-12656770 - LT1 Piston Oil Squirter
2014+ 8 required
28-11546665 - 2014+ LT1 ENGINE BLOCK
PLUG
28-1453658 - GM Transmission Dowel Pins
168-930228070 - Mahle Motorsports LT1
Gen 5 Piston Set, 416ci, 4.070bore,
4.000stroke, 6.125rod, 1.105c/h, .927pin, -22ccvol,
412g, 10.0c/r, 2618 Forged
168-6457147 - Mahle Upgraded HD Wrist
Pin for TSP Exclusive Piston Sets, Per Pin
25-TSPLT1VVT-3-10 - Texas Speed & Performance Gen
5 LT1 VVT-3 Camshaft w/ +10% Fuel Lobe: 235/239,
.645"/.635", 116 LSA, 112 ICL
333-25-315717 - LT Camshaft Core 5150
28-SDCrateSB - GM Engine Crate for Short-Block
Engine Assembly
28-SDCradle - GM LT Engine Cradle for Engine With
Oil Pan
In addition to my Texas Speed and Performance order, I am also purchasing a Cordes Performance supplemental fuel
system with the Lingenfelter HPFP.
My heads will be re-inspected and I will re-use those if all is
up to par. Texas Speed and Performance already did a
porting job on them.
...and a side touch. Just pulled my wheels off today and will have them powder coated a new color: Bengal Black w/ Prismatic Silver Sparkle. LOL!
wt., 21 Quarts
4340 Forged
LT1 6.2L
PLUG (BARBELL)
BLOCK
2014+ 8 required
PLUG
Engine Assembly
Oil Pan
As for our previous level, yes, we were 1k+ rwhp.
I sort of wrote the book on lash caps for the LT1/LT4 and how to spec them properly after several members, myself included had lash cap problems, many of which were installed by these so called "professional shops". Check out the thread here:
https://www.corvetteforum.com/forums...learances.html
Ant 🐜
Ant 🐜
As for the Lingenfelter pump, I was just told from a well known C7 builder / business, that they've witnessed the death of a few Lingenfelter pumps within hours after installing the Lingenfelter 10% increased flow HPFP on a 32% fuel lobe cam. They said the issue is on the hard throttle to immediate throttle release under heavy acceleration.
wt., 21 Quarts
4340 Forged
LT1 6.2L
PLUG (BARBELL)
BLOCK
2014+ 8 required
PLUG
Engine Assembly
Oil Pan
Have estimated build time? Would love to check it out sometime if that's ok. I'm just east of Dallas and always up for a cruise in my new toy.
We concede that we pushed our stock parts too far. We had the Wiseco / Vengeance Racing drop in LT1 forged pistons, stock crank, stock rods.. TS&P heads / cam package (TS&P VVT1 camshaft). 21.3 pounds of boost on our ECS 2200 blower + tons of meth, American Racing Headers, full Corsa Extreme exhaust, no cats, LT4 HPFP, beefed up bolts, springs, pushrods, etc.
This is a good forum thread to share other owners misfortunes in the sense of: Here is what I "had" engine-wise / modification-wise before it died. Hopefully current and future owners can take the information provided here and learn about LT1 / LT4 limitations.
On a side note, our 416 build is coming along. We think TS&P might have finally gotten our Callies Magnum crank back in stock and I've got to call Weapon X today on our upcoming fuel and drive pulley additions blah blah blah..
