Bleeding C7 Z51 brakes
I won't do the ABS with the computer, just plain old bleeding.
Would like to know if there are two bleeder nuts on each rotor front and back.
Also, looks like you do RR/LR/RF/LF?? Is this with the tech II and just manually? That is, on the c6z06 it's RF and LR as one system, and the other two as the other, so you bleed as a pair. Not sure what order is best when doing it manually or if it really matters.
Will be using a pressure bleeder. The DIY thread says 25psi! That's high, is that really needed or can I go 15 as the bleeder recommends?
I've looked through stuff and can't get good answers to these possibly over-**** questions, but it would help me to know, so Thanks!.
bill
bill
Cheers.
Cheers.
This is helpful info from Theta.
https://www.corvetteforum.com/forums...ure-specs.html
I can't believe that when you open a bleeder screw to gravity it doesn't leak around the threads. But I suppose with no pressure but gravity it goes out the hole.. My Z06 leaks a ton when pressure bleeding or 2-man pumping (no laughing people). We used the pressure bleeding and it went just fine, and I think there is an advantage to each system. Pressure bleeding is fast and one person, but has a lot of possible contamination potential (like from the grease on the pump that comes with the system). The pressure sure did push a lot of little particles out rapidly. Not sure these would come by gravity, but never tried it.
tips I learned: I use a 6point socket to loosen all bleeder bolts as the open end ones can strip if they are on tight. I did do RR/LF/LR/RF. His clutch fluid was as bad as mine was at 13K miles... Some vette stuff doesn't change...
Oh, and the car ran great at the track. It isn't a c6z06, but the new C7 stingray (I first drove it on the track, the way it should be!) is a beauty. The brakes were adequate. The 7 sp manual was hard to get used to and no, no car needs 7 forward gears. I challenge anyone to find a track where 6 is needed, much less 7.. So 2 "overdrive" gears for the hwy?? Really? But really, a super nice happy fun ride compared to my bruiser Z... And almost as quick.
Oh, and we put those cooling rings on... and between that and the unicorn tears we spritzed on them, not sure which cools the brakes more..
Thanks for the helpful posts above.
