EFILIVE Software Update
Old Sep 25, 2015 | 02:44 AM
tblu92's Avatar
tblu92
St. Jude Donor '13-'14-'15
Default EFILIVE Software Update
Just received the latest update from EFILIVE ( Sept 15th) and they have added approx. 30-40 new tables in the C7 or E92 computers
Some are simply re-configurations of existing tables but most are new tables--Many of them are "0"rd out which in the past always meant that these are new items that are coming in the future
The new tables include :
Brake TQ management
TCM TQ management
Several "variable intake manifold" tables
OBDII readiness tests ( ability to permanently set or change them)
Old Sep 25, 2015 | 08:23 AM
hnaskoct's Avatar
hnaskoct
So im guessing these updates are a good thing,since tq management plays such a big part in these cars...i wonder if its possible for the cars to become more aggressive when accelerating
Old Sep 26, 2015 | 12:24 AM
tblu92's Avatar
tblu92
Even with the previous version of their software you can make your C7 very aggressive from idle--
As an example I tuned a '14 Z71 A6 and without even touching the timing tables or fuel tables the car became extremely lurchy---So much the owner's wife while pulling into the garage knocked the mirror off !! So I had to De-tune the car to make his wife happy !!
These E92 ECM;s are so much different than ever before and tuning is actually simpler
A The biggest stock tuning flaw is that even if you floor the throttle--it does NOT go to WOT until you reach approx. 3600 RPM's- really makes them a dog off the line---this is tunable---and the 1st thing I do---I try to explain tuning tables to HP guys on the forum and they have no idea what I am speaking of---There are so many tables in EFILIVE that unlock HP and TQ and throttle response as I mentioned that don't even mess with spark and fuel--- and after making timing adjustments and minor fuel adjustments these cars are simply nasty
Stock timing example-------
-negative timing up to 1000 RPM
up to 1600 only 5* of timing
up to 2000 RPM's only 12* of timing
up to 2600 RPM's less than 20* of timing
The new A6 converter has a higher stall than ever before like 2000
So there is no reason not to have gobs of timing down that low as the engine is not under any load---Even minor changes in these areas can make your car "ramp up" thru the lower RPM range and fry your tires until you lift---Not gonna happen with a stock tune---
Old Sep 26, 2015 | 01:01 AM
hnaskoct's Avatar
hnaskoct
Man u really seem to kno what your talking about!!!...ive been lookin for someone to explain to me why the c6 is more aggressive especially with a stall vs the c7 a6 with stall...seems the c6 throw sum niiice 60ft times...best i see the c7 do is 1.6s and high 1.5s....and in drag racing that 60ft is important
Old Sep 28, 2015 | 06:52 PM
flynhi's Avatar
flynhi
Default Warranty Impact
Will these tuning mods void my warranty?
Old Sep 28, 2015 | 07:31 PM
Higgs Boson's Avatar
Higgs Boson
No offense tblu, but welcome to Fall 2013....I am surprised EFILive is just now making some of those tables available!
Old Sep 28, 2015 | 07:32 PM
Higgs Boson
the simple act of having a tune doesn't void your warranty. is that what you are asking?
Old Sep 28, 2015 | 07:33 PM
Higgs Boson
i keep checking the dates of the posts on this thread to make sure it wasn't brought back from the dead.....
Old Sep 28, 2015 | 07:49 PM
BLKTA's Avatar
BLKTA
EFILive only recently starting updating the E92 ECM in earnest. Took forever, but better late than never.
Old Sep 28, 2015 | 11:11 PM
Zip Corvettes's Avatar
Zip Corvettes
Platinum Supporting Vendor
That is kind of misleading. If your car has any calibration change your driveling warranty is affected, not the entire warranty. So if you go to the dealer because you have an engine or trans or diff failure and they see that the factory calibration is not there, then you will be covering the costs of repair. If you go to have your touch screen radio fixed, you will get the car back in a couple of days fixed and no bill.
Old Sep 28, 2015 | 11:48 PM
Higgs Boson
Saying the driveline/drivetrain warranty is affected is also misleading.
A tune is not going to cause an oil leak, for example. A tune will also need to be proven to cause the failure. If they look at the combustion chamber and find evidence of preignition induced ring land failure, yes you may be with the bill. If your valve drops LS7 style, they are going to have to explain, maybe in court, how a tune caused that.
The are accounts of repairs being warrantied with a tune, and trust me, having worked for the corporate side of the business, the manufacturer is no more excited about taking a warranty claim to court as the customer. If they aren't positive it's going to hold up, they are going to make the repair.
On the positive side, does anyone ask themselves why we don't have 1000s or even 100s of examples to set ourselves a precedent? It's because it just doesn't happen very much! If there is an engine problem, it usually is epidemic, and if you suffer failure from a tune, you know it.....I don't think I have ever seen a bone stock engine failure caused by a tune.....I have seen plenty of bad tunes on highly modified cars though, that eventually fail. There's a big difference, imo.
Old Sep 29, 2015 | 09:40 AM
Zip Corvettes
I agree with most of it, I think it really comes down to a dealer. I had a dealer to work on our duramax if it had any tune on it, which it didn't. The dealer can absolutely deny the warranty if the calibration has been touched. They don't have to prove anything though, the car is not as they delivered. With that being said I don't think either party would want to go to court because if that calibration was altered you may have to answer more questions then you would really like and be opening up a can of worms. I think for the most part people are honest and if they screw something up they fix it. I don't think allot of tuners have seen the really big picture here. EPA.
To EFILIVE Software Update
