My friend has a 2015 mn7, z51. He told me the other day when he started his car it ran wide open and pinned the tach. He immediately shut it off, waited a few minutes and refired. The car acted normal after that. What could possibly cause that. Pretty scary.
There are a lot of variables that could cause that to happen. However, the engine should be OK. The Rev limiter kept it from over revving. Even if you hold the gas pedal to the floor with the transmission in neutral it will not over rev.
I've had that happen on mine and attributed it to a combo of the tune and ported throttle body and have been working through the issue. I pick the car up from Vengeance tomorrow and am hoping my little gremlins like that are behind me. Is his car stock?
Same here every now and then something weird happens--- I just shut if off- restart and it always resets itself and is fine--
I have a ported T-Body as well--It did a few times go to WOT at start up-- But be comforted that there are several engine protection programs in place that help protect your engine--especially when it's cold---RPM limiter---set by coolant temp-oil pressure etc------
Similar experience but not WOT. Started up the car two weeks ago, first morning start, and it got stuck idling above 1K for about 5-10mins, sounded like a boat engine running. It usually lowers rpm after 2min. But I kept waiting to see if it was going to ramp down and it never did, until I turned it off.
Hmm, maybe this is what caused my faulty cat converter? Dumping too much fuel in
Mine did it yesterday at a car show. Lots of people standing around as a witness. They must have thought I was an idiot reving my engine after the show was over.
I tried blipping the throttle but it didn't help. Made it worse, actually Shut it off after about 4 seconds. Restarted and it ran normally. I just idled away without touching the gas pedal.
Has to be a bug in the software controlling the throttle blade. Could be on start up the ECU gets a false reading from one of the TPS, MAP or MAF sensors. The only thing I can think of to prevent it is to keep your foot away from the gas pedal for a couple of seconds. I would think there would be a fail safe line of code to limit RPM on start up until all sensors stabilize. Makes no sense that RPM instantly goes 6000 rpm. While I did not look a the tach, it was way up there.
To compound matters, the exhaust was extremely loud as I was parked in one of those street type shopping malls and the sound just bounces off the buildings. My NPP was open and I have headers too. I just installed a ported throttle body. I can't believe that has anything to do with it.
