How to install a sub amp from start to finish
#63
To disable the noise cancellation, the cabin microphones must be disconnected:
See the picture in post#11 to identify the X3 connector. Pull the pins out (or cut the wires) that go to Pin#4 (Light Green with Brown stripe) and pin#5 (Light Blue with Yellow stripe).
The pin numbers of X3 are shown in the 18th picture in post#1.
#64
Lc2i do I need?
Do I need a low output converter like the lc2i? For a 19 vette with bose system? I'm trying to find out everything I need to attempt to install my subwooby myself
#65
Question
it worked perfectly on my 2017 C7 Z06. The solid yellow wire from X1connector from factory amp is the +right front door sub and the yellow with black stripe is the -right front door sub. Here are the pics of my install with close up of the speaker wire you tap into and my ground and power. From the +yellow and -yellow and black speaker wire I used a LC2i. So the +yellow and -black and yellow wires go into the LC2i speaker wire positive and negative locations. I powered the LC2i straight to my battery just like My amp and the LC2i ground went into the same ground as amp. The LC2i remote wire "OUT" went into my amp remote wire in, to turn my amp on. The LC2i WILL NOT TURN ON until music is coming out of the speaker wires. It senses a current from the speaker wire and that what turns the LC2i on. The LC2i will not turn on with just with power and ground hooked up. (I thought mine was a dud because I hooked up the power and ground but NOTHING happened. Not until I put the speaker wire from the +yellow and the -yellow and black, did the LC2i turn on.) you then put the RCA sub out from the LC2i to your amp. When the LC2i senses music it will then turn on then turn on your amp. Remember remote wire out from LC2i to remote wire in to your amp or your amp will not turn on. I used the LC2i cause it sounded better than the $20 ones and it's adjustable and will turn your amp on. Here are some pics
Ground goes here for amp and LC2i
Power here
This is from X1 connector and the 2 yellows you use are here
The 2 yellows you tap into for your speaker wires
Ground
Power
The LC2i
Power
Power here
Ground
Power
The LC2i
Power
#67
#68
#69
Thanks for the write-up! For those of you looking for a 12v remote source (my converter's auto-on has never worked right) fuse #37 is what you want to tap. It turns off when you open the door after turning the car off.
#71
This is an awesome write up with great replies too! So good I thought I had it in the bag! Can anyone tell me why my wiring colors are different than the other posts? Trying to find the ANC mic wires and the front right door woofer.
'16 Z06 2LZ
Any help appreciated, thanks!!
Never mind that post, I figured it out.
But...does anyone have a easy way to run the bass **** from the amp to the front of the car?
Thanks!
'16 Z06 2LZ
Thanks!
