Storing the car with meth
Old Oct 31, 2015 | 03:28 PM
NoOne's Avatar
NoOne
Default Storing the car with meth
My assumption is that alcohol won't freeze but getting ready to put the car up for the winter.
Gasoline loses octane over size but any concerns with meth when starting up in the spring?
Most likely will be in a non-freezing garage but figured I'd ask.
Old Oct 31, 2015 | 07:05 PM
robert miller's Avatar
robert miller
No dont do it that stuff is really bad on parts. I am saying if you let it set for any amount of time it will not be good on the metal parts..
Old Oct 31, 2015 | 10:14 PM
NoOne's Avatar
NoOne
How do you drain it?
Old Oct 31, 2015 | 10:25 PM
robert miller
Get a hand pump only a few $$ then run it empty thur the system. Really man if I was going to not run are start the car for 2 r 3 months no way I would let that stuff set in it for that time..
Old Nov 1, 2015 | 07:43 AM
C7&7's Avatar
C7&7
What metal parts? It's in a plastic tank?
Old Nov 1, 2015 | 09:53 AM
NoOne's Avatar
NoOne
The meth sits in there 365 days a year, if its static or moving its still in the system.
Old Nov 1, 2015 | 11:05 AM
C7&7's Avatar
C7&7
Yea don't worry about it. It's no different than fuel.
Old Nov 1, 2015 | 11:19 AM
robert miller
Give Juno a call on it, then why do they tell you to send the pump back every 2 years to have it rebuild. To me letting this stuff set in the car for 2 r 3 months you are asking for problems...
Old Nov 1, 2015 | 11:27 AM
C7&7's Avatar
C7&7
Robert...I get it. I do...
But the pump comes on and pumps meth on demand right...so the pump does not "have fuel sitting in it" if a car is stored. The meth is in the tank and what little could be left over in the lines to the tank or from the pump.
The pump isn't sitting pressurized.
Old Nov 2, 2015 | 09:21 AM
StingerBG's Avatar
StingerBG
One concern I would have, if you are using 100% meth and have the car tuned leaning on the meth, is that meth will actually draw in any moisture that may be present, which will dilute the meth a little depending on how well the system is sealed. Now if you're not too aggressively tuned against the meth, then you'll probably be ok.
To Storing the car with meth
