Something's not right. Possible meth problems....
Old Jan 5, 2016 | 12:44 PM
  #161
T/A KID's Avatar
T/A KID
Originally Posted by imxz28
I know you're close to maxing out the stock fuel system but one 15gph nozzle should do the trick. I think the AFR needs to be tweaked a bit. You don't want to be dependent on meth to that degree.
Everyone at that power level on the stock fuel system is meth dependent lol
Only way not to be at this power level is add a cam with a lobe upgrade or install the lt4 hardware
Old Jan 5, 2016 | 02:40 PM
  #162
Higgs Boson's Avatar
Higgs Boson
If it were me, I'd bump the initial pressure a bit, be sure the turn on is at 3psi and set the gain back to around 6 AND go back to one 15 gph nozzle. Then get a retune around those parameters. Now you have your own wideband and can watch over things closely.
One 15 gph will spray 5.33 fluid oz in a 10 second pass.
Like TA said, if you are a little dependent on meth, you are 100% dependent on it. Doesn't matter if you need one or two nozzles, if you're out of fuel, you are out of fuel.
As Fyreant knows, his meth kit at 8 with 2 nozzles is compensating for a lean non-meth tune. The right way to do it, as he knows, is to properly tune it to .8 (rather than .9) lambda without meth as good as he can, then introduce the meth and finish up. You end up using less meth and more gasoline but the results are not really going to be any different though. Where he is now with PE fueling, he needs a screw but has a zip tie.....
I have some nice screws in my laptop bag but there's more licensing fees to pay and his tuner can do it for free.
Old Jan 5, 2016 | 03:40 PM
  #163
officermartinez's Avatar
officermartinez
Just saw your "UPDATE" post FYREANT. Awesome! So, are ya back from the dead now and ready for some hootin' and hollerin' ????
Old Jan 6, 2016 | 12:19 AM
  #164
FYREANT's Avatar
FYREANT
I'm Batman..
Pro Mechanic
Curious, but since I am meth dependent, how would you be able to tune without meth and then introduce it later?
hahaha that's funny right there lol. I took the car out for a decent ride tonight. Got on it many times. It didn't act up once! Now that I know that its "healed" (as opposed to it acting fine after an assumed fix to only find it broken again the next day) I will call my tuner tomorrow to go over the plan for fix. Don't worry, if that doesn't pan out, I'll be looking to pick up some titanium "screws" from you lol
I would say so! Still need some adjustments to the tune but overall its running MUCH better!
Old Jan 6, 2016 | 12:24 AM
  #165
Higgs Boson
PM you
Old Jan 14, 2016 | 08:16 PM
  #166
FYREANT's Avatar
FYREANT
I'm Batman..
Pro Mechanic
I may be getting together with my tuner tomorrow evening to get my tune adjusted as needed. Then it's go time for the drag strip on Saturday morning! Stay tuned!
Old Jan 14, 2016 | 08:30 PM
  #167
C7&7's Avatar
C7&7
Bad ***!!! Glad it's all going your way dude!!! Post some results at the track.
