if he's local just pull it with his laptop, the easiest.
Yeah good idea. I am hoping he has that laptop down here since he splits time between FL and IA. Going to call him tomorrow morning about it. stay tuned..
Just looked at the tune... I doubt it's the issue...
Fuel targets .86 lambda till about 4K then targets .85..
Spark is around 13-14 in high cylinder load (boost region) so timing looks fine...
The maf has lower g/sec values in the upper hz, but your running twin nozzle meth so the tuner pulled out fuel from the maf and based off your recent WB pulls with a single nozzle I think fuel is solid....
Start of injection is around 400 crank degrees... Thats real early but I've seen similiar in other boosted setups.... (I've never had to start it that early, but to each there own)
Peak tq is way high... Looked at DD and it matches... I would make sure this setup is going 100% throttle... Be a quick test
Few other things, but overall the tune looks pretty good IMO..
Well that sounds like good news, thanks for reviewing it for me. Higgs reviewed the tune and there are some thing he would do differently that may be the reason I had issues "breaking up". What do you think the cause of the weird sound is in the video I posted in post 110? If your listening to it on computer speakers and you turn it up you can hear a weird bass like sound coming in and out around 2-3 seconds into the video. Thats the main issue. The car changes tone and feel when that happens..
i think it's too lean, too much timing, and start of injection is too early. he is blowing fuel out of an open exhaust valve, spraying through the spark and the ECM is pulling timing down towards TDC to try to prevent it and is probably even lighting after TDC.... it's leaning out because it's out of injector. the tune is commanded lean to try and preserve injector but it's not working.
would love to see a log with injector duty cycle, rail pressure, fuel pressure, spark and spark retard, etc.
Hook up the 2nd nozzle and record lambda or AFR, that will tell us that.. The ECU is commanding less fuel that a factory c7 at WOT, but I believe the tuner pulled out fuel to compensate for much meth... Hard to tell that by looking, but the WV will tell the tell..
SOI does look early like I mentioned.. I've had good luck on similiar builds shooting for 360 crank degrees, Never tried it in the 400+ range to know, but Higgs could be right on with that!!
I usually setup 93/meth cars for 12-14 degrees of timing personally
I agree with Higgs.... It would seem rail pressure was dropping off considering such high SOI, BUT your really not commanding a lot of fuel from the ECU, rather your getting it from meth... Never run out of meth in that rig...
I'll hook the second nozzle back up and do a recording tomorrow as long as it doesn't rain. Rained all day today unfortunately. Good thing I always top off the meth before I pull out of the garage lol
I am willing to bet it was either set up blind off another tune (copy/paste) or it was tuned off meth first and then reset the MAF curve while spraying.
Do you still have the HPT and cable? I can email you a config or two to log with while you make some runs.
I do still have the HPT and cable but do I need credits to do the logging? There are no credits on the tuner assigned to my vehicle since it isn't my tuner..
No I don't think you need credits to log. I've never not had credits so I am not sure, ha.
Since I use my laptop for business It is attached at the hip....
Looks like you pulled the tune after I got all the information. Glad it's working.
When I was working with Torrie McPhail on my Flex using an SCT tuner, I logged all of those things + dual Lambda's, RPM, MPH & more (up to 20 items) when doing WOT runs.
How many items can be logged simultaneously with HP Tuners Pro?
Hoping that Ant can get his Innovate plugged in to analog port on my HP Tuner Pro. Eventually want to set up an Innovate on my Vette once I get a bigger urge to add headers, tune + E-85.
Ok.. This may be the update everyone is waiting on.. lol
I've been working with Higgs in the background on this to try and figure things out and we may have it close to being the way it should be. HUGE THANKS TO HIGGS for taking time to look at this for me! I got home today, and put my second meth nozzle back on and also swapped out my new plug wires. Took the car out and did a run and Lambda came in around .89-.90 at WOT. Still toooo lean. Meth was at level 6 mind you, which is where I am tuned at. Higgs had me put the meth at level 8 and redo another pull. I did that, and now the Lambda is between .80-.84, which is right where it should be. AND, the car is not making that weird sound anymore!
I've done a handful of pulls so far and the sound has not returned yet. It would see as though the sound I was hearing may have been the ECM retarding things due to the lean condition. I am going to take the car out tomorrow night after work and put it through some paces to really test it out and if all looks good then there are a few changes I will need to get with my tuner on, but overall it should be fixed!
I know you're close to maxing out the stock fuel system but one 15gph nozzle should do the trick. I think the AFR needs to be tweaked a bit. You don't want to be dependent on meth to that degree.
If it were me, I'd bump the initial pressure a bit, be sure the turn on is at 3psi and set the gain back to around 6 AND go back to one 15 gph nozzle. Then get a retune around those parameters. Now you have your own wideband and can watch over things closely.
One 15 gph will spray 5.33 fluid oz in a 10 second pass.
