Something's not right. Possible meth problems....
How much power did you put down? You could very well be spraying through the spark event and depending on what the tuner did with some of the spark retard tables, the ECM may not have the authority to retard spark enough to keep it lit.
640 at the wheels, you need meth to compensate for the lack of injector (LT1s). I just tuned one around the same power level. PM me (or us) for the email addresses.
Valone MotorSports
16260 Old US41s
239-872-4309
Its sounds like the problem is in your tune. I see issues like this when only the Start of Injector timing was changed and not much else for fueling.
You have a direct injection motor. What was your WOT Air Fuel Ratio?
Valone MotorSports
16260 Old US41s
239-872-4309
Cylinder 1: 215 PSI
Cylinder 2: 205 PSI
Cylinder 3: 219 PSI
Cylinder 4: 206 PSI
Cylinder 5: 220 PSI
Cylinder 6: 208 PSI
Cylinder 7: 217 PSI
Cylinder 8: 210 PSI
Im surprised the PSI is as high as it is actually. Figured it would be around 175ish. Anyway, its a bit difficult to get the gauge tight in the passenger side plug ports so im going to harbor freight to get a set of shorty wrenches. Been looking for an excuse to get a set for a while anyway. Once I get back home i'll finish up the test and have the rest of the results. Stay tuned..
I put the new plugs in, gapped them to .037" this time. New plug wires will be here tomorrow, guess they got delayed due to the holidays. For the time being, I put the old wires back on and took it out for a spin. The first 2 times I hit it, (2nd and 3rd gear pull) the car felt great, strong, and did not stumble. The second time, the issue came back again lol. We took video of it the second time, which I have posted below.
Remember, this is with single nozzle meth setup. I am tuned for dual nozzle, but have the second nozzle disconnected for troubleshooting. Haven't put it back on yet.
Also, PLEASE, using your COMPUTER speakers NOT your mobile phone, listen to the sound the engine is making through this pull and you will clearly hear the issue that is happening. On a phone you cannot hear the change in sound.
http://vid556.photobucket.com/albums...a/IMG_1228.mp4
I'm a bit boggled by the fact that the A/F is showing it running SOO rich even with the second meth nozzle disconnected. I figured I would be seeing it run extra lean..
I vote it's time to focus on the tune parameters. Certainly sounds like something is very wrong. I don't think I'd be playing with it too much until you find the culprit
I can't figure out why it would be running so rich since I pulled the second meth nozzle. You would think it would make it go lean..
Also assuming this is on the drivers side?? At your power level you need meth for a supplement the for fuel and a single 15gph nozzle would only change AFR about 1 point... I don't recall what nozzle you have
Could always have a bung welded in the other side and retest... Need to send that file to Higgs and I and I could tell real quick what fuel looks like
Let's say it showed 10.5 during cruise which should be 14.5
Then WOT looked to be around 8.8 on average which would be 12.8 (little lean for FI C7, hence your second nozzle which is around 10gph guessing which would put you close to 12.0)
