Lash caps
Old Dec 6, 2015 | 07:13 PM
BJ67's Avatar
BJ67
Default Lash caps
Can someone tell me what are the benefits of using LS7 lash caps on the LT1 motor.
Old Dec 6, 2015 | 09:50 PM
Higgs Boson's Avatar
Higgs Boson
Don't do it at all. Some have come out and gotten lost in the oil system. They were a bandaid before we knew how to tune right...
Old Dec 6, 2015 | 10:44 PM
FYREANT's Avatar
FYREANT
I'm Batman..
Pro Mechanic
don't do it. We unfortunately found out the hard way..
Old Dec 7, 2015 | 08:52 AM
BJ67's Avatar
BJ67
Thanks guys, I needed that.
Old Dec 8, 2015 | 01:05 PM
Mike02z's Avatar
Mike02z
I agree, don't do it! My tuner said it was not needed even at 700 RWHP. I have not had any fueling issues since my mods went in. If you need a higher volume pump, you will need to break down and by the Z06 pump. I think they are around 850.00
Old Dec 9, 2015 | 06:17 PM
DoubleDown's Avatar
DoubleDown
Has anyone had a positive experience with the lash cap? I had one installed before reading about the nightmare situations others have had. I have not had any problems with it... is this something I should be concerned about or are most of the problems occurring during install or when paired with the z06 HP fuel pump?
Old Dec 9, 2015 | 06:57 PM
Bucknut2006's Avatar
Bucknut2006
Have the LS7 lash cap with a 32% lobe cam and LT4 pump. No issues.
Old Dec 9, 2015 | 07:40 PM
Higgs Boson
I have the stock cam lobe! I wonder how much production tolerance there is here.
Old Dec 9, 2015 | 08:42 PM
Cordes Performance Racing's Avatar
Supporting Vendor
Done quite a few especially in the beginning of this all w/ zero failures to date. Not saying we are doing some magical other's are not but never had a failure. I always prefer doing the C7Z pump if money allows and no cam has been installed.
Old Dec 10, 2015 | 04:21 AM
Elite '14's Avatar
Elite '14
I have the same, no issues so far.
Old Dec 10, 2015 | 07:30 AM
Elite275's Avatar
Elite275
Same here. I think VR uses a Comp Cams lash cap vs the OEM one though if makes a difference.
Old Dec 10, 2015 | 08:16 AM
Higgs Boson
as with all things, most are going to be fine. there is an assumed risk that I don't think people really knew about before deciding.
Old Dec 10, 2015 | 02:24 PM
T/A KID's Avatar
T/A KID
How many of you have the stock cam??
Old Dec 11, 2015 | 07:50 AM
Elite275's Avatar
Elite275
VR Stage II here.
Old Dec 11, 2015 | 09:15 AM
Motohead279's Avatar
Motohead279
I know some people have dropped theirs into their motor while trying to install it. But do you know of any instances where one has fallen out after already being installed?
Old Dec 11, 2015 | 10:52 AM
Higgs Boson
yes, mine.
the lash cap created enough lift on the pump rod to push the LT4 pump off the block by shearing the mounting bolts!!
I couldn't figure out why I lost control of fueling until I pulled the intake. Oh ****!!!
Anyways, installed a new one with no lash cap, it still holds pressure but the LT4 injectors are too small for my application so I am waiting on an Alky Control kit to arrive.
Old Dec 11, 2015 | 11:42 AM
T/A KID's Avatar
T/A KID
About to install the lt4 hpfp and lt4 injectors on my 15.... Tempted to install my ls7 lashcap but I seen what happen to Higgs :/
Kind of torn
To Lash caps
Old Dec 11, 2015 | 01:03 PM
FYREANT's Avatar
FYREANT
I'm Batman..
Pro Mechanic
Kind of torn
don't do it!
Old Dec 11, 2015 | 01:04 PM
Higgs Boson
apparently the LT4 stroke is shorter than LT1 so it is more risky than the LT1 with lashcap.
also, the 2015s have a lot of similar fuel pump data LT1 vs LT4. The 2014s were different, maybe different FPCM or something.
let me know if you need any help with data.
Old Dec 11, 2015 | 01:28 PM
T/A KID's Avatar
T/A KID
Higgs I recall you having crazy fuel trims using lt4 injector data on your 14..... I'm going to use stock lt4 hpfp data for now and attempt to install lt4 injector data if I have the same issues I may just keep the injector data stock for the lt1 or just change from 121 to 140 for the injector size and retry....
