Gauge problem-help please
Old Dec 11, 2015 | 12:43 AM
vinnie12345's Avatar
vinnie12345
Default Gauge problem-help please
Just finished my SC install and everything works awesome except....
My analog temp gauge works perfect, but the digital gauge never moves it stays dead stick on 100. My digital redline never moves up showing the car is warmed up even after driving for an hr. I also get a Service vehicle soon light every time I start the car. It shows no codes so I'm guesting it has something to do with the temp gauge not reading.
Any thoughts???
Old Dec 11, 2015 | 12:52 AM
vinnie12345
Originally Posted by vinnie12345
just finished my sc install and everything works awesome except....
My analog temp gauge works perfect, but the digital gauge never moves it stays dead stick on 100. My digital redline never moves up showing the car is warmed up even after driving for an hr. I also get a service vehicle soon light every time i start the car. It shows no codes so i'm guesting it has something to do with the temp gauge not reading.
Any thoughts???
Attachment 47937640
Old Dec 11, 2015 | 02:34 PM
vinnie12345
Bump
Old Dec 11, 2015 | 03:28 PM
StingerBG's Avatar
StingerBG
Who tuned it? Sounds like it is something in the tune. What SC kit did you install?
Old Dec 11, 2015 | 06:48 PM
vinnie12345
I installed it, ECS kit, meth and TSP headers. The tune was done by a friend with help and input from Doug @ ECS.
I origanly thought I had a bad coolant temp sensor but the analog gauge works fine and was told there is only one sensor. I'm stumped because if there is only one sensor how am I getting a good reading on one display and no reading on the other?
Old Dec 12, 2015 | 07:18 AM
Steven Popham's Avatar
Steven Popham
St. Jude Donor '16
Maybe the coolant sensor is left unplugged by accident or it was loose
Edit Just read your reply, so I don't know
Old Dec 12, 2015 | 08:31 AM
Elite275's Avatar
Elite275
The analog is basically a dummy gauge. Try unhooking the battery and then reconnect after 5 min or so and see if it resets.
Did you also install a new thermostat as well by any chance?
Old Dec 12, 2015 | 10:58 AM
vinnie12345
The coolant sensor is plugged in and is relaying the correct temp to the analog temp gauge. If it was unplugged or not working that gauge would be dead also I am guessing.. Thanks for the suggestion..
Old Dec 12, 2015 | 11:00 AM
vinnie12345
I'll try unhooking the battery. Yes I did install a new 160* stat. What do you mean dummy gauge?
Old Dec 12, 2015 | 04:32 PM
Elite275's Avatar
Elite275
I just mean that the analog gauge doesn't really display the temp. It's there for looks so to speak. It shouldn't read 0 though. To get a good temp reading view the digital gauge in Tour mode.
Make sure whoever did the tune updated it to accommodate for the 160* thermostat. It's a simple update but easily overlooked especially if the tuner wasn't aware of the new tsat.
Old Dec 12, 2015 | 04:35 PM
C7&7's Avatar
C7&7
This is absolutely in the tune. Similar thing happened to me with oil temp.
Call Doug and chat with him he'll know.
Old Dec 12, 2015 | 07:33 PM
vinnie12345
OK, So I feel like a complete bone head.! The gauge I was looking at is the Trans temp gauge. That gauge hardly moves even after driving for 30-40 minutes. So the redline warm up bar above the tach takes forever to move up because the transmission is taking so long to warm up. So, I thought the "service vehicle soon" was because of a faulty gauge. So I guess the only issue I have to figure out is why my "service vehicle soon" comes on at every start-up. (I hooked up a code reader and it says no codes but the light comes on every start-up)
Does everyone’s car take so long to warm up the tranny when its 55*-60* outside?
Thank you
Old Dec 12, 2015 | 07:42 PM
C7&7's Avatar
C7&7
I never look at trans temp. Just care about coolant and oil temps. It takes 15 minutes to come up to temp on both.
Does the service engine soon message go away then just back and start up? No codes though?? Do you have a check engine light?
Thank you
Old Dec 12, 2015 | 07:51 PM
vinnie12345
The "service vehicle soon" light comes on at start-up and goes away when I press ignore and stays off for good till i turn the car off then back on and there it is again. No check engine light.
Old Dec 12, 2015 | 10:11 PM
CDH76's Avatar
CDH76
What is your oil life percentage at?
Old Dec 13, 2015 | 01:49 AM
HANNY's Avatar
HANNY
service vehicle soon isn't the same as check engine light. it means service engine soon like your oil life is close to being up. Reset your oil % and see what happens
Old Dec 13, 2015 | 10:06 AM
Elite275's Avatar
Elite275
Thank you
I agree with others about the service vehicle light.
I have a 160 thermostat in my car and the warm up bar above the tach rarely goes away. It's ok though. I monitor the temps and when cool they are at least 170 or above once the car gets to operating temp.
To Gauge problem-help please
Old Dec 13, 2015 | 12:50 PM
vinnie12345
100% and still on.
It has to be something in the tune like a rear O2 sensor needs to be shut off or something like that since I have X pipe with no cats.
Old Dec 18, 2017 | 01:02 PM
mittens's Avatar
mittens
so anyone ever fix the tach issue with the cooler thermostat?
Old Nov 15, 2020 | 10:40 AM
Lilharv321's Avatar
Lilharv321
100% and still on.
Did you ever get this figured out? Mine just came on.
