Does anyone track with a SC?
Thanks for noticing, we have come to realize that this is a very addicting game we play, so we try and make it as easy as possible to upgrade the HP without having to make any changes with the base supercharger kit. I think we have achieved that better then any other centrifugal company.
That's strange, is the car lowered? Either way though, our offer stands indefinitely.
I guess they are making some with the std bolt pattern, cool! It's a nice looking intake, although we make as much power as the engine can handle without it just using our base kit so it's more for looks at that point. Plus the aluminum will heat soak more on a street car. I'm not sure I would recommend it unless you were going for an "all out 2200R in our case, or F1x type build in Prochargers. Same goes for any aluminum intake just so that's clear.
Doug does the lip that can be welded on top provide similar performance as the lower pieces?
The way i perceive it, heat is the enemy and makes the engine go boom.
thanks for the cam advice, but here in germany it is hard to get someone to do that work, and the places that do do it, charge an arm and a leg, so u are back in the SC territory money wise.
Perhaps a better option for me is an oil catch can, basic bolt ons, and oil cooler upgrade...
With all the track experience that GM has, I am surprised that they made their flagship car suffer from heat issues. My c6Z06 never had those.
Huge jumps in torque and HP over shorter RPM ranges.
Here are just a couple suggestions:
1) The best route for you to take if you just want to add a good amount of hp and keep things reliable for road racing, then a mild cam kit (including VVT, springs, retainers, push rods, timing chain, etc), some headers, a CAI, and a tune would be your best bet. Although like you said, this could get very expensive over in your country compared to a SC install. Here, a package like that usually runs about the same as a SC/headers/tune package runs but nets just a tad lower hp.
2) Or go the SC route. I would either recommend ECS (with welded scoop) or the A&A kit. Both will make great reliable power but both will have higher IAT's than a naturally aspirated setup like above. So you may also benefit from a methenol injection system to help keep those IAT's down. I would recommend installing one but keep the tuning conservative so that you aren't leaning on the meth but only using it for safety. Granted, this will just add something else for you to have to monitor and keep on hand to refill when needed. You will burn through quite a bit of meth when on the track. However, if you just tune the car for 93 octane (or 91, whatever you have there) and don't lean on the meth, then it wont really matter too much if you run out as it was only there as an added safety to begin with. Just a thought.
Either route you choose, I would HIGHLY recommend going ahead and upgrading your cooling either way. GM makes a few factory parts now to help with that such as a higher amp radiator fan and a secondary radiator setup (that comes on z06's, which further benefits from a Z06 grill installed). You could also look at after market options here (which is what I'm going to do). LG and DeWitts both make great aftermarket radiators which, from what I've gathered, help to decrease the average engine temps by approximately 25-40 degrees. LG also makes a few other great components to help with cooling like a better transmission cooler and larger transmission pan for a higher capacity of trans fluid. I would also recommend getting some type of catch can with any route you go. If you go forced induction, FPS makes a great application for this.
I personally do not get the chance to road race near as much as you, but I still plan on adding a few of these options just to keep my car safe. I'll most likely go with the ECS kit with welded scoop (I've already removed my lower air dam, for looks purpose only so I'll need the scoop), ARH long tube headers and x-pipe with high flow cats, Vengeance plugs and plug wires, FPS catch can/breather, and a DeWitts or LG radiator with upgraded GM radiator fan. I'm skipping on the meth for now because I don't want to have something else to keep up with.
C5/C6 and C7 Supercharging Specialist
ECS Supercharger Kits / Mantic Clutches
www.EastCoastSupercharging.com
Facebook Page
ECS YouTube Channel
http://95octane.com/2014/09/22/2015-...e-c7-stingray/
http://en.geigercars.de/corvette.html
When I bought the Corvette I decided to keep in NA, and went the Cam route with headers, upgraded DeWitts radiator, and long tube headers. This car can run with just about anything on the track including previous generation Z06's. A blower was not a consideration for me, you just simply have too much heat being created, on a car that struggles to shed heat as it is.
I have done all of the cooling upgrades I can to mine and it remains reliable, fast and fun. I don't have to worry about watching my temps rise as the session goes on.
I made over 500whp on a Mustang Dyno with just a cam upgrade over headers and intake. It was over 100whp and the car now spins to 7000 rpm, perfect for road racing.
nurburgring without the car overheating (both tranny temps and oil temps start to go up to the red at the end of second lap, if I drove it hard). This next season i'll also add spa and hockenheim to my track list, which usually create more heat.
So right now i'm contemplating adding xpipe, ported and coated stock manifolds, CAI and larger throttle body, but that will only add 30hp and put me $1500 in a hole. So I was thinking of just throwing one of those $5k SC instead (seems like better $ per HP value), but i'm seriously concerned about heat issues. Is there anyone that has a SC and does hard driving without heat issues? How much is the cars balance affected by a SC system?
I used to have E90 M3 that I ended up SC'ing (ESS 575 kit, to a final output of 600bhp, roughly 510whp) and I never had heat issues with it, and the car's balance was not ruined. I ran many track events, even did Spa in the rain with no significant issues. It handled just as well as when it was stock, and was very manageable and didn't try to kill me.
However, in my opinion the first and second shift gears are to s
hort for the 573 whp the car is producing, thus traction is compromised with the oem tires.. IMO a n/a would be a better option for road racing.
For the autobahn the SC c7 should be great.
