C7 Tech2 equiv?
Old Feb 28, 2016 | 12:26 PM
Joe C5's Avatar
Joe C5
You can go here to see if there is anything new for your car without signing up.
Not sure how up to date it is but I have used it in the past.
https://tis2web.service.gm.com/tis2web
Old Feb 28, 2016 | 02:05 PM
y2kvett's Avatar
y2kvett
Default Thanks a bunch!
Originally Posted by sycraft
I use the ELM 327 bluetooth adapter- around 10 bucks- with the Torque app. can see data and clear codes if needed. all this for under 20 bucks.
I noticed that there is a torque lite for free or the pro for $5. I think I will get the pro, but what is the difference. Also, do you have to be connected to the Internet to use torque? I like to use my iPad..,easier to read and type on than iPhone.
Old Feb 28, 2016 | 03:32 PM
sycraft's Avatar
sycraft
Not sure , i use the Pro version, its cheap enough. I can data log with it too if needed. Not necessary to connect to internet, unless you want to add some add ins. I have not done that
Old Feb 28, 2016 | 10:46 PM
Bill Dearborn's Avatar
Bill Dearborn
Problem with the Elm tools and cell phone software is it doesn't access anything but power train codes. Not as useful for debugging a problem since it can't issue commands or see about 45% of the codes that can exist on the car. On new cars most of the problems aren't powertrain problems.
Bill
Old Mar 3, 2016 | 02:38 PM
y2kvett's Avatar
y2kvett
Default iPhone?
I can't find the Torque Pro on the app store for my iPhone.
Does it work on an iPhone?
Old Mar 3, 2016 | 04:05 PM
sycraft's Avatar
sycraft
I do not believe I-Phone is compatible
Old Sep 15, 2016 | 11:20 AM
C7fasttoy's Avatar
C7fasttoy
So I am getting familiar with Corvettes. I am interested to have a tool with full capabilities including diagnosis so on this case looks like MDI or J2534 is required and GDS2 software that can be download after subscription ( 3 days ). Does the GDS2 will expire after 3 days? What else the subscription provide?
Regarding service manual what is the best option to have them? I read on ACDelco something called GMSi but that requires subscription and really expensive. I just need C7 manuals not the whole GM portfolio.
Old Sep 15, 2016 | 03:32 PM
y2kvett's Avatar
y2kvett
Default Blue Driver
I'm looking at the Blue Driver when my 2014 warranty expires. It is only $100 and works thru the iPhone. https://www.lemurmonitors.com/ Check out their site, it will tell you all the codes and monitors.
