Radiator fan fuse
Jan 24, 2016 | 11:49 AM
Radiator fan fuse
Ok, I'm feeling a little dumb here.
My radiator fan will not shut off even when engine is off. I waited about 20 minutes and just decided to disconnect the battery.
I want to just pull the fuse not disconnect the battery. I would like to know which number fuse it is in the fuse box.
Jan 24, 2016 | 01:56 PM
Jan 24, 2016 | 02:14 PM
Quote:
Originally Posted by
meyerweb
Thank you,
Jan 24, 2016 | 02:19 PM
Do you have a low temp thermostat, i.e. 160 or other non stock?
If yes, certain ones can cause this non shut off.
Jan 24, 2016 | 02:50 PM
FKING1
Yes I did put a lower temp tstat to just delay how soon the fan would come on.
Its been fine for the last year or so.
Jan 24, 2016 | 03:07 PM
Dazed Confused & Verklemp
Sure sounds like a failed Tstat. Been there twice.
Where did you get it from? What temp is it?
Lots of posts and several threads on this problem. Several solutions.
Jan 24, 2016 | 03:22 PM
tstat
EcoBrick Bob
I think its the Tstat as well.
Its 180 not to much lower than stock. With the fan running all the time water temp would not get above 140 and oil 130.
Jan 24, 2016 | 05:31 PM
roadg
I had a 160 that was OK for 6 months before the fan problem.
Replaced it with an LMR stat & no more prob.
Jan 24, 2016 | 05:41 PM
air in system, tstat stuck (would think the temp gauge would read high if that was the issue but maybe not) or fan relay stuck on
Jan 24, 2016 | 06:41 PM
HANNY
It is a little strange, it probably is the tstat or relay.
Thanks for the feedback.
Jan 24, 2016 | 07:01 PM
roadg
Not to beat a dead horse, but, put the original thermostat back in and see if the fan is OK.
Jan 25, 2016 | 02:30 PM
FKING1
Replaced the Tstat and all is well!!!
