Trunk 350amp fuse dead...
Link to purchase: https://www.delcity.net/store/MEGA-F...oaArftEALw_wcB
starters wrong will blow it.
My problem ended up being a bearing failure. So my engine is essentially done for. I have big HP so wasn’t too surprising. Going to order a new LME short block with forged internals to handle 1400 wheel HP and swap my upgraded heads and parts over to it. The motor cranks over with coils unplugged but if it runs it seizes up pretty fast it’s for sure a bearing failure. I will have it pulled apart soon.
The car is nearly stock electronically; there is remnants of a Curb Alert installed at the front fuse box but hardly a cause for blowing 350A fuse.
And with the small but recent cases of other cars having their 350A fuse suspected of failing, I am wondering what is the cause?
You're right, there aren't many reported cases of this fuse blowing.
I do know that hooking up a charger wrong, or one of those portable jump starters wrong, will cause it to blow.
Other trends I noticed - people who install headers have not properly shielded the wire to the starter from the heat thrown off by the headers, and that has caused a few of the reported issues.
I have seen at least two cases reported where people installing pulleys for a certain brand of superchargers tightened them down to a point where some screw interfered with the rotation and basically locked up the engine. When they went to start it the starter motor of course couldn't turn, began overheating, and the fuse blew.
Then there is the case in this thread, similar to one or two others I ran across. Anything that causes the starter not to be able to crank the engine will blow that fuse.
None of this explains my case and a couple others I ran across. In my case I picked up my car that morning brand new, and drove about 200 miles to my sister's house. Right after I left the dealer lot, the service rear axle message came on in the DIC. I figured brand new car, WTF, hit OK and the message went away and I've never seen it since. All was great until the last 2 miles. I stopped at a traffic light. When the light turned green, I could not get it to go into any gear (manual 7 speed trans). I shut it off and on about 3 or 4 times and it finally went into gear. Then I noticed the clutch pedal was sticking about halfway, and to get it all the way up I had to hook my left foot behind it and pull. The car started running really rough and shaking but I managed to get it to my sisters driveway and pulled in. I put it in neutral and the engine was still running. I decided to pull up a tad, and put the clutch pedal down, put it in 1st, started to let off the clutch, which was still sticking, and the engine just died and I had to use the emergency door releases to get out. The clutch pedal was again stuck half way up. I tried to restart, nothing, no dash lights, no starter clicks, no nothing. DOA. In retrospect, I wonder if pressing and holding the starter with my foot off the clutch and brake would have brought me into maintenance mode but I didn't think of it at the time. I have the AAA super duper Platinum plan which gives you one free tow up to 200 miles, so I had it flatbedded back to the dealer who diagnosed that the fuse was blown, but could not figure out what made it blow. They pulled the fuse block off another car on the lot and put it into my Z06 and all has been fine since, 2600 miles and 9 months.
So maybe hitting the starter 3 or 4 times with pausing in between to try to wrestle the car into gear may have overheated the starter, but the car still ran, got me about 2 miles to my sisters house, and I had dash lights so the fuse wasn't blown, just a mushy clutch pedal and the engine running really rough like it was misfiring on one or two cylinders (never verified by stored codes). The 350A fuse didn't actually blow until I put it in gear and tried to move forward in my sister's driveway.
I suspect either a defective fuse, or the fuse block wasn't tightened down properly at the factory and during my drive it loosened up. I don't know what else to chalk it up to. I have a lift at home and looking at everything underneath the car, there is no sign anywhere of sparking and arcing/burn marks that you might expect from blowing a 350A fuse.
All I know is that I now have a spare fuse block on hand, and several of those Del City 350A Mega fuses in case the problem ever rears its ugly head again. Bizarre. Not a common issue, but has happened to several people for no apparent reason.
If this happens to you, please post your story about it, and any causes or solutions. Thanks and sorry for the long read. Hope this helps someone in the future.
Last edited by Null Pointer; Feb 12, 2020 at 10:39 AM. Reason: added commas for clarification
[snip]
Now I did put a jumper on the car a few nights ago but the symptoms were already that of a blown fuse. So not definitive that jump killed the fuse.
Thanks to the post about Del City fuse. I ordered 6 in case there is a debug nightmare that the root cause is still there vs. a transient jump that may have killed it.
1. Car was not driven 2-3 weeks and failed to start - battery had 2015 date stamp on it, 46K miles since new
2. Assumed battery was dead, bought an Interstate AGM battery from Costco
3. Mistakenly thought 350A fuse blown - it was intact (but I already bought spare aftermarket 350A fuses for diagnosing it)
4. Unable to tighten Positive clamp on new AGM battery - positive terminal was just a bit too small.
5. Returned battery to Costco, bought a regular battery from Walmart and installed.
6. Car initially powered up but no door opening nor DIC lighting up.
7. Disconnected and resigned to towing to garage.
8. In act of desperation, I rechecked the clamps - the positive clamp was on but not tightened.
9. Once both clamps were tight, put fob in steering column, DIC light up and started.
10. Car was in 'transport mode' and turned off using the procedure found on web (not quite accurate, but got it done).
I don't know why the fob was ignored for several days when I tried to replace battery. Fuse was OK.
My theory is the battery died and I got a slightly undersized Positive post on the AGM battery - causing me to think other problems (blown fuse).
So, car is running fine now - will take my fuses and solder on thick wires/copper eye connectors as emergency fuse jumpers for emergency use.
Hope this helps someone in the future and thanks to all that helped me check out the issues during the debug phase.
Eddie
