It will be fine without headers. The C7 stock manifolds flow pretty well. If you add headers on before the cam or after the cam you will get similar gains.
You should see between 455 and 457 HP at the wheels, but it could vary a bit if the E85 isn't exactly 85% Ethanol. Sometimes it is more like E 60 even though they label it as E85.
Not goin with a small cam it's a blower cam but it's aggressive they told me it adds around 55 to 60 whp sometimes 70 but I didn't ask if that's with headers is I could get 60whp from the cam alone I would be satisfied
Personally I don't want a cam that only adds 35whp lol
Reason I'm postin this tryin to see if anyone added a cam without the headers and how was the performance
I seen a lot of c6-z06's
Added cams without headers and they seen good performances
With the mods I'm
Doin will I see possible 10sec runs I'm really more into my trap speed I want high 120s to 130
In my view, you buy headers for a C7 because you like the sound. Headers provide minimum gains on the C7. The stock C7 Cam has a pretty good design. I'd rather put my money towards a Supercharger. More bang for the buck and you don't have to open the engine. YMMV
I do have LT's because the C7 sounds a little wimpy to me with the stock manifolds and the twin cats.
I agree with the supercharger but the cam I'm goin with is for a super charger it will allow me to make more power with less boost also I could have good power with out the s/c
I'm just tryin to find out if I will get good power without the headers and make it into the 10's with my setup
You know one of the vendors here is making a primary cat delete pipe. should cost around 300-400 bucks and stupid easy installed compared to headers. that might be a great option instead of headers for people looking for more sound.
Yup, not remotely close to the LT's though. At least not at ~700 RWHP
header install was a joke. I just had someone else do it
To the OP, you may get into the 10's with your planned setup but there is a lot we don't know. M7 or A6/8? Drag radials? One of the biggest helps on the 1/4 mile is drag radials for the C7.
Sorry
M7 goin with r888 on stock wheel. E85 ported tb and intake
