"Track" alignment vs "Street"
Old Jun 9, 2016 | 09:46 PM
owc6's Avatar
owc6
If you put any number of miles on the car at all (between track events), then the street-neutral alignment is the best thing you can do for your tire longevity.
If you track, then you must do what you must for your track performance.
There is no in between, IMO.
Old Jul 31, 2018 | 11:17 PM
80atez's Avatar
80atez
Agreed!
I just went back to "street" alignment after about 8 years of a track alignment on my c6z06. It is obvious to me driving the car that it doesn't turn it as quick. Some call this "twitchiness". Seems to me to be "responsiveness". Only driven once on the new setup, but I'm not sure I like this sloppy feel of the street alignment I now have... Even though I pretty much don't track my car anymore.
I guess my point is, if you're thinking of going to a track alignment because you want sharp turn in, you should try it, if you are thinking about going back to street, you may have forgotten how much of a difference it makes!
Old Aug 1, 2018 | 10:11 AM
Dane@LGmotorsports's Avatar
Dane@LGmotorsports
Premium Supporting Vendor
Originally Posted by Pachis
After my one track day the outer edges of my front tires were worn MUCH more than the inside. This after my local dealer did the Track Alignment.
I was suspicious so I had an independent shop do a check. I've attached copies of the 'actual' check alignment comparison with 'regular' spec, Track spec and actual. Documentation for each also included. It would seem that the outside tire wear is explained by the actual readings.
Outside cupping can prematurely wear if you aren't braking enough before/at turn in and leaning on the fronts through the first part of the corner. Not saying that it's the cause in your situation, just something to keep in mind.
Old Aug 4, 2018 | 01:16 PM
jonparks's Avatar
jonparks
Originally Posted by X25
I'll personally just go with the track settings and leave them as they are. After all, -2 camber is not that aggressive, and it would be cheaper and less time consuming to leave the alignment and just replace tires a little bit faster.
Old Aug 4, 2018 | 07:01 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
Our 2017 Z51 has 9k miles on the original PSS runflats. At about 1k miles the suspension was set to a very slight toe-in front and rear, very close to 0 toe. Camber at -.6 on the LF and -.8 on the RF, rechecked recently and it hasn't changed.
We have been using the car as a DD and long distance straight-road tripper, only one autocross weekend and no HPDE.
The tires look good to a visual inspection, but a tread depth gauge shows that the innermost groove on all four tires is a full 1/32" less than the other grooves. That means I will probably lose about 20% of my tire life by the time the inner groove gets to 2/32", the center will be about 3/32" and the outer at 4/32".
The "fault" is mine, I had expected to be driving more aggressively to get more even tire wear. On our c6, I ran a bit more negative camber and the wear was pretty even but I was driving the car much more aggressively. We need to match the (negative) camber with our driving style. This time, I guessed wrong.
Old Aug 5, 2018 | 08:47 AM
80atez's Avatar
80atez
I will probably wait until I am going to track mine again and go back to a less aggressive track alignment in the front and leave it.. I hate detuning my car. Makes me feel old. Thanks for the input everyone.
