i think I saw something in the forum on adding "cold air intakes" to the C7. Do they make that much of a difference? And is there a difference in the aftermarket brands, K&N, Haller, etc?
AFE has been very popular, and probably the best bang for the buck. Throttle response is crisper, and you will love the throaty intake sound. I think there are a couple available right now in the parts for sale section:
found aFe on line, I like the window idea to let you know the condition of the filter, K&N is completely open and the Halltech is totally enclosed. just what I have found so far. with concerns of "computer" sensitivity on any add-ons I am hoping for any further investigation into these things.
I installed aFe to my 2014 after I added Corsa Exhaust. I had it dyno tuned because of more air in and out and was pleasantly surprised to get an additional 47 rwhp.
From what I have read, be careful with oil coated filter elements (like K&N), too much oil on them can mess up the MAF sensor, and not enough will let dirt through. I would stick with dry paper elements, for whichever system I would choose.
To one of the above guys with only a cold air intake and a set of cat back with a tune and a gain of 47 hp one hell of a tuner. Robert
I looked at going with an aFe cai but after looking at the published flow reports and talking to local tuner I decided just to go with a K&N filter replacement.
According to aFe and K&N's websites the aFe cai has a flow of 318 cfm @ 1.5 H20 for approx. 500.00. K&N on the other hand published that their filter flows 312 cfm @ 1.5 H20 and only cost 65.00.
I have also read numerous post on here that say the factory air box flows well.
Personally I don't see 6 cfm of airflow being that much of a difference.
Hmm, yeah definitely not worth an extra $435 for just 6 cfm extra. Halltech lists their intake at 689 cfm @ 1.5" H2O. You can find this one for around $600. Another option for those that are interested. http://www.halltechsystems.com/Hallt...R-p/strlt1.htm
Could this be due the AFE flow number being a system number whereas the KN is for the filter only? In other words, what is the system for the KN in the OE housing and connecting tube?
I have a Halltech CAI, Ktech TB & Faster Proms (Formato) intake manifold, but an otherwise stock Z51 A8. I turned an 11.8 when temp was almost 80 and the DA was between 1300-1500 at Bradenton (30 ft ALT - VERY humid). I get a little throttle stutter from Ktech TB (based on other posts) when the car is cold, but once at driving temps, it runs flawlessly.
If you don't mind me asking.....what was your trap speed? I ran 11.88@118.31 bone stock convertible. DA 1100 TEMPERATURE around 65 at Bradenton.
from what I have seen its nothing like the c6 cold air. since the air comes in exactly where it does stock I see no difference there. Better filter alone will gain some cfm's and maybe the tube add's a little but really its not doing much.
Now on the c6 it did both ram air and cold air so there was a bigger gain. I haven't seen and neither has my tuner who does only vetts seen any cold air that is adding much of anything except like I said a better flowing "filter"
but it's your car so do what you like. its a forum so guys just have to believe what they want and leave the rest.
I installed the aFe airbox on my 2015 Z-51. Very well made system. Easy to see the filter and determine when it is time to clean it. The sound is a little deeper. I like to track the car once a month. My lap times have been coming down every session. Hard to say if its experience, fresh tires, cooler temps, better drivers on the track or the aFe system.
Bottom line - aFe made my experience more enjoyable.
I have afe, butt dyno says no hp was added. IMO waste of money.
I think the Green filter (PN 7225) is plenty after reviewing all of the flow data. There's no point in going with the AFE from a performance enhancing perspective.
Try searching the Z06 threads, I would guess over 50 different forum members with about 20 differect shops showing dyno gains from around 30hp to 45+hp no tune just CAI swap. I have installed both the Halltech and now AFE. I can for sure feel the difference. The problem for us Z06 guys is the filter is same size as the Stingray so it is a restriction. I can not say the same for the Stingray? I am very pleased with the HP/TQ gains.
