Vac Leak or Bad Sensor???
Old Mar 21, 2016 | 11:48 PM
dbratten's Avatar
dbratten
Default Vac Leak or Bad Sensor???
On my 2016 Z06 A8 I am having an annoying and somewhat dangerous problem in that the car does not want to slow down when letting off the gas. In town it is very noticeable, especially in paddle mode when I downshift, expect the car to slow down, but instead it stays at the same speed or even accelerates a little. I also confirmed that it does this at high speed when I have downshifted to 4th or 3rd and it only slightly slows or again speeds up until it has gone far enough to finally lose speed. The only way to get it slowed down is to use the brakes.
I have considered that it maybe a vacuum leak but the idle is steady. I am thinking it may have something to do with the rev-matching or a sensor on the throttle-body. There aren't any codes shown.
I stopped by the dealer and took the tech for a ride and it showed him that even at slow speed (25-40) in first gear (paddle) letting off the gas slowed a bit and then blipped up in speed all without my foot on the gas pedal. They did a quick check and didn't see anything posted by GM and I will need to drop the car off for them to research it further. I plan to do that this week.
Before that, I wanted any learned advice on what it may be.
Thanks.
--Dan
Old Mar 22, 2016 | 11:59 AM
Muuhaha's Avatar
Muuhaha
Basically, you're trying to engine brake?
Old Mar 22, 2016 | 04:27 PM
dbratten's Avatar
dbratten
I am expecting the car to slow down when I let off the gas like every other car I've ever owned. If there was any engine braking that would really be good. If downshifting slowed the car, even better.
Old Mar 22, 2016 | 07:03 PM
T/A KID's Avatar
T/A KID
Any mods or bone stock??
Old Mar 22, 2016 | 07:36 PM
dbratten's Avatar
dbratten
Yes, should have mentioned -- AFE CAI and an Elite Oil Catch Can. I checked both thinking it could be a vacuum leak but not finding any issue.
--Dan
Old Mar 22, 2016 | 07:51 PM
T/A KID's Avatar
T/A KID
--Dan
Did it do this before??
Old Mar 22, 2016 | 10:58 PM
ktoonsez's Avatar
ktoonsez
--Dan
Exactly! First rule in debug is start eliminating things, I.E. your mods. Start with the catch can (which it probably will be), if it isn't the can put the stock intake back in. In a long shot situation it could be the Afe if you have the gen 1 and the AFR is so far off its making you gain speed.
Old Mar 22, 2016 | 11:03 PM
dbratten's Avatar
dbratten
I'm just not sure. Car now has 880 miles on it and I wasn't paying close attention to it until I started to push it more and use the paddles. If left in auto mode it is tough to feel what's happening as it's always in a higher gear than if I was driving it normally.
I dropped it at the dealer this afternoon and we'll see what they find.
Old Mar 22, 2016 | 11:07 PM
dbratten's Avatar
dbratten
Would the Afe improve flow that much?
Are you familiar with the Elite can? Is there something in the vacuum line routing that could cause this?
Thanks.
Old Mar 22, 2016 | 11:29 PM
ktoonsez's Avatar
ktoonsez
It wouldn't be the airflow as much as the Fuel Trim percentage error that is created with that intake.
I do not have one on my C7 but all I know is there is a 10 million page thread in the Z06 section about people arguing about whether its needed, whether it causes problems..... Thats why I said start there because I know I have seen vacuum issue with it whether they were installer error or the device itself I am not sure.
Hopefully the dealer will be able to figure it out quickly.
Old Mar 24, 2016 | 12:13 PM
ktoonsez's Avatar
ktoonsez
I'm curious what the dealer found, any update?
Old Mar 25, 2016 | 01:56 AM
dbratten's Avatar
dbratten
Without too much effort they sent me home saying to put on more miles. The claim is that the A8 needs upwards of 2k miles to correctly learn its shift points.
I think it does have something to do with one of the mods and will pull one off at a time when I have the time and check to see what happens. It's not that I doubt what GM is saying but that so few, if any others, are having the same issue.
I'll look into the fuel trim as you suggested.
Thanks.
--Dan
Old Mar 25, 2016 | 12:04 PM
ktoonsez's Avatar
ktoonsez
Thanks.
--Dan
If you are an Android user, you can download Torque and use that to display the LTFTs and see if it is above 15%
Old Mar 25, 2016 | 03:45 PM
dbratten's Avatar
dbratten
No, I'm a total Mac user. I do have HPTuners on my Air laptop but have never attempted to look at LTFTs -- or know what they are. I used the software to mainly change parameters between street and race on my C6 but I have licensed my C7 to tune.
To Vac Leak or Bad Sensor???
