Add a Hobbs Switch???
Old Mar 28, 2016 | 02:02 PM
Dave01GT's Avatar
Dave01GT
Default Add a Hobbs Switch???
What is the best place and way to add a Hobbs switch? Just get a T and go into the bypass valve vacuum and add a hose and clamp to the Hobbs? Is there anything that can be added where the Hobbs switch can be threaded in?
Old Mar 28, 2016 | 02:27 PM
T/A KID's Avatar
T/A KID
Assume this is for a secondary fuel pump system to activate in boost??
You can place the Hobbs switch where it will see boost...
Old Mar 28, 2016 | 02:29 PM
Dave01GT's Avatar
Dave01GT
Yep. Just wasn't sure since it is threaded. Didn't know if just clamping a hose on the threads and then putting it on a T would be fine or not.
Old Mar 28, 2016 | 02:31 PM
T/A KID's Avatar
T/A KID
You can thread it right into the intake or charge pipe...
Otherwise I would get a fitting that connects to the end and clamp it down..
To Add a Hobbs Switch???
