Help with Mode Selector
Old Apr 9, 2016 | 04:06 PM
Drdavid121's Avatar
Drdavid121
Default Help with Mode Selector
Forum members:
Mode selector won't change, all the other displays work i.e. radio ect. The mode selector is stuck on touring mode.. I wasn't able to locate a fuse that might be the culprit. Any advice would be appreciated.
Drdavid121
Old Apr 10, 2016 | 01:26 AM
Rooster OG's Avatar
Rooster OG
St. Jude Donor '15
If it's still under warranty I'd take it in.
Old Apr 10, 2016 | 08:56 AM
BRCC's Avatar
BRCC
Might check the obvious, scroll down to Settings and verify you are linked to Drive Mode and not Tour.
If that is not the fix your only option is the Dealer.
Old Apr 10, 2016 | 09:52 AM
NSC5's Avatar
NSC5
Check like BRCC stated and watch for the letter indicator at the bottom of the center dash display, not the overall layout because the letter indicator will always change to indicate mode when the mode changes regardless of what is linked to the mode selector. I leave my Z06 locked to the sport dash with ECT in the center of the tach but the letter indicator will still follow/indicate mode changes.
The mode switch does need to be rotated to the stop point to change modes, a quick flick of the **** won't reliably change modes.
Does valet mode lock out mode changes? If so make sure you or your significant other didn't place it in valet mode.
Old Apr 10, 2016 | 09:54 AM
Zymurgy's Avatar
Zymurgy
Moderator
This is undoubtedly the correct answer. To link the IP to the driver mode, see this thread: Linking IP Gauges to Driver Mode Selector.
Old Apr 10, 2016 | 10:46 AM
Drdavid121's Avatar
Drdavid121
Default Thanks for your advise
Spot on everything is back the I had it truly appreciate your advice help
Old Apr 10, 2016 | 10:48 AM
Drdavid121's Avatar
Drdavid121
Zymurgy. Thanks . Everything is the I had it before, I appreciate your advise. Drdavid121
To Help with Mode Selector
