I'm running my cat at the 1/4 tomorrow and I'm planning on a few passes with the launch control. I'm just wondering if all the nannies are shut off while using launch control in track mode?
I know traction control will be off, just wondering if the car hits 2nd gear hard if it could break loose?
This is on a Z51 car without mrc so no sub levels in track mode.
I have run my base 1LT non Z51 with ZF1, have your tires and wheels.
If you are running on a bright sun warmed well prepped track and you warm the tires enough, you will not spin hitting second gear.
I have done this power shifting, no trac control, no launch control, all nannies off.
