e-Diff: How is it different from Limited Slip
Old Jun 7, 2016 | 10:17 AM
NTMD8R's Avatar
NTMD8R
Default e-Diff: How is it different from Limited Slip
So, how is the e-Diff different from a "normal" Limited Slip Differential ?
How does it work differently ?
How can you tell if it is working correctly ?
Can it fail ?
If so, how can you tell ?
Is it adjustable ?
If it is not working correctly, how to fix it ?
Old Jun 7, 2016 | 10:19 AM
juanvaldez's Avatar
juanvaldez
It is electronic. It is controlled by the computer.
Old Jun 7, 2016 | 11:25 AM
NTMD8R's Avatar
NTMD8R
juan,
thanks for your response.
But I am asking for some specifics.... how is it different from a "regular" one.
I know the manual describes some things.
I need to know if mine is working correctly... how can I determine this?
If it is not, how can I get it corrected (or can i ?) ?
If it is working correctly, can I adjust (tweak) any of the settings ?
Old Jun 7, 2016 | 03:15 PM
DesertDog56's Avatar
DesertDog56
Here's a short video from Chevrolet:
Old Jul 6, 2016 | 10:43 PM
NTMD8R's Avatar
NTMD8R
Well, sorry guys... but none of this is actually answering my questions.
I would like to know just how it works......
does it use fluids?
how does it control both wheels/axles separately?
what parameters does it use to make this control happen?
etc., etc., etc.
I can't get any answers from my GM dealer.
So can ANYONE help me?
Old Jul 7, 2016 | 12:36 AM
Higgs Boson's Avatar
Higgs Boson
http://www.stingrayforums.com/forum/...html#post11538
Old Jul 7, 2016 | 10:36 AM
NTMD8R's Avatar
NTMD8R
Wow, Higgs....... Thanks so very much.
Old Jul 7, 2016 | 01:05 PM
Bucknut2006's Avatar
Bucknut2006
Dubbed eLSD in GM speak, the suggestively named diff comes standard with the Z51 Performance Package, and employs a hydraulically actuated clutch that infinitely varies the amount of engagement, going from open to full lock in tenths of a second. Fully integrated with the stability-control and Performance Traction Management systems, the system controls the differential according to an algorithm that factors in vehicle speed, steering input, and throttle position.
Basically, it works a lot like a regular LSD, but used fluid to vary the clutch pressure.
To e-Diff: How is it different from Limited Slip
