LT1 416 stroker
I am currently working on my LT1 going with a 416 stroker for boost (twin turbo), I got callies crank,callies rods Wiseco pistons, head studs, and 226/236 lsa 114 cam(not sure about the cam) and ported polished heads. my main concern is wat to use for main bearings, rod bearings and head gasket (maybe lt4) or should I just buy a new set of the stock ones. other question is fueling I am doing dual intank fuel pumps with a fuel regulator going to stock fuel lines, do you know wat controllers the guys are using for secondary port injectors.
thank you
