Track alignments
Old Jun 23, 2016 | 10:47 AM
AKKutz's Avatar
AKKutz
Default Track alignments
I was just told, by my Chevy dealer, that they only align cars to factory specs! WTH?!
Isn't the track alignment given in the manual a Chevy factory Spec?
It's enough to make you start looking for a more compliant Chevy dealer!!!
Old Jun 23, 2016 | 03:36 PM
Bill Dearborn's Avatar
Bill Dearborn
They need to look in their bulletins to find the information from GM. Most dealers and their mechanics are just like independent mechanics. Used to attending to grocery getters and are some what lost when somebody comes in asks them something like that.
I am attaching the February 2016 bulletin from GM. Make sure they have ALL of the proper equipment to do the job. Most dealers don't realize that rear caster is adjustable on Corvettes and have no idea they need to measure it and adjust if required. Their shop manual has the specs but they don't seem to understand they need special equipment to do it. This is one of the ask Tadge questions he responded to. You may find it difficult to find any dealer or independent shop that can do this since two specialized tools are required.
I had to purchase the tools myself so I could take them to the dealer to do the rear caster adjustment. The final tool just arrived at my house this week.
Bill
Old Jun 23, 2016 | 03:54 PM
AKKutz's Avatar
AKKutz
Bill
Thanks Bill. I am still waiting for another dealer to call me back, they were "going to check with their mechanic". I called my dealer's service manager, but he hasn't returned my calls also. I guess next step is to call GM customer service to see if they can direct me to a dealer in my area that can perform the operation.
Old Jun 24, 2016 | 05:03 PM
baron95's Avatar
baron95
I had a track alignment as a condition of purchase my Z51, which the dealer agreed to. It took their service department 3 days to try to figure out (ned needed to order the right tool, etc). In the end they did it, on condition that I sign a stupid release.
Next time around, I asked Town Fair Tire alignment guy to do it (I bought new tires from them). I was skeptical, told them if it was hard or they were unsure to just leave it alone. Car came out with perfect track alignment - with front camber really close to -2.0 which is hard to get to without pulling washers, etc.
The guy said there was nothing hard or difficult about it. I gave him a tip, and now that is where I'll do my alignment.
Old Jun 24, 2016 | 05:19 PM
AKKutz's Avatar
AKKutz
Be nice if they were in my town! I had a shop that used to do all my track alignments, but that was 20 years ago and they are no longer around.
Old Jun 24, 2016 | 05:40 PM
Bill Dearborn
That still doesn't get you the rear caster measured/adjusted. Highly unlikely an independent shop would have paid $133.00 for the special adapter that fits in the rear knuckles and provides a vertical mounting location for the angle gauge plus the cost of the gauge. Minimal gauge cost is in the $30 region. The GM gauge runs somewhere around $500 but may be easier to use and more accurate. Besides the common alignment rack and supporting equipment here is what is required to complete the alignment properly.
The yellow arrows in this picture show where the adapter is fitted into the rear knuckle.
The gauge has to be read while the mechanic is under the car adjusting rear camber using the alignment machine readings and adjusting caster using the gauge fastened to the adapter. According to GM documentation camber is most affected by adjusting the front of the rear lca and caster is most affected while adjusting the rear of the rear lca.
Very few cars have adjustable rear caster and it is highly unlikely most alignment mechanics have ever had to adjust rear caster. Cars that I know that have rear caster adjustability are the Pontiac Solstice and Saturn Sky and I have seen comments that some Mercedes models may have this capability.
Billl
Old Jun 25, 2016 | 06:03 AM
spearfish25's Avatar
spearfish25
Hey Bill, do you have part number for the adapter and GM gauge?
I thought you also noted that a -2.0 camber without pulling washers leads to a noise and rubbing.
Old Jun 29, 2016 | 08:55 AM
dfettero's Avatar
dfettero
Default Northern VA Track Alignment?
Anyone know of a Northern VA dealer that can do a track alignment?
Old Jun 29, 2016 | 10:35 AM
MSR's Avatar
MSR
For what it's worth, I measured max possible front camber in all 3 configurations on my 2016 Z51. I was shocked to find that it got -3.7L and -3.8R with zero spacers and maxed eccentrics. Even with both spacers back in, I still get -2.9 degrees. I left it that way so there's no question of SCCA Solo legality with removing spacers. I have zero rubbing problems with the stock tires.
It is about 0.5" lower than how it was delivered, so there's some camber gain from that. The height adjusters aren't even close to bottomed out.
Michael
Old Jun 30, 2016 | 11:24 AM
AKKutz's Avatar
AKKutz
Update: dealer to do the alignment. My selling dealer, after calling their service manager finally gets back to me with they don't have the tools, but bring the car in we will figure it out. My guy has 20 years in the alignment business.
The dealer closest to my home (whom I bought trucks from, but couldn't get together on the Vette price) said they will get the tools needed on a lend/lease program and give me a call to get me in and perform the alignment. So, I'm going to ask them to try for -2.5 in the front without removing shims and see what happens. Also, going to ask for the rear to be adjusted without removing shims.
Old Jun 30, 2016 | 02:32 PM
hisvett's Avatar
hisvett
St. Jude Donor '14-'15
Get friendly with your local Firestone Tire dealer; they offer a "Lifetime Wheel Alignment" package for just over $200. I have been using them for the last three Vettes with no issues. I talk to the alignment guy, we go over my specs and life is good. I take my car in about every 6 months or so (or before each long road trip). If I want to set it up for a little track use, I will give my alignment guy my track specs.
Now if your lucky like me, you may get an alignment tech that has lots of experience setting up a fleet of Corvettes for a local track school at one of your local tracks (Texas Motor Speedway)
Old Jul 2, 2016 | 01:35 PM
Bill Dearborn
Part number for the adapter bracket is CH-47960-10 and the gauge is CH-47960. The gauge is expensive so it would be better to find a lower cost one.
Yes, the mechanic who did my alignment didn't pull the single spacer from behind the UCA as the GM Instructions state. He used the cams in the LCAs to push the LCAs out as far as he could get them and that resulted in the washer on the spring bolt rubbing on the control arm which makes a clunking noise as the suspension goes up and down. Especially on starting and stopping in a straight line.
Bill
Old Jul 2, 2016 | 01:40 PM
Bill Dearborn
The rear caster may or may not need to be reset once they adjust the camber. The problem is without the tools they have no way of knowing what it is. There is no way for an experienced alignment mechanic to get around not having the tools. If they don't have the adapter they can use two quarter inch bolts stuck in the holes in the knuckle but they still need a gauge. The gauge in the pictures I posted in this tread earlier probably isn't the best one to use since it only has .2 deg of accuracy which means you have a .4 deg of uncertainty around any measurement you take. Supposedly the same company makes a more accurate model which would be the better to one to use.
Bill
Old Jul 2, 2016 | 01:42 PM
Bill Dearborn
He still needs to be able to read the rear caster angle to know what it is. That means he needs at least a gauge and two quarter inch bolts.
Bill
Old Jul 3, 2016 | 06:49 PM
arturox2's Avatar
arturox2
Not sure about N VA. I would check with Criswell Chevrolet in Gaithersburg, MD. The Corvette tech (Luke) told me they do track alignments. Dina Bartolomeo is an excellent service rep (301) 212-4528) to work with--recommended by Mike Furman.
Old Jul 6, 2016 | 11:04 AM
savage's Avatar
savage
Bill
Bill these are the GM part numbers?? I'm going to buy my own setup and take it to alignment shop ( I'm under the car the whole time with them) please steer me in the right direction for what I need and where to get/buy it from, thanks
Old Jul 6, 2016 | 02:27 PM
savage's Avatar
savage
Found meters on eBay , $19.00 and up and dealer has bracket I can barrow when needed, he wanted $160.00 for one , I told him if I pay 160 from him I will buy my next car across river from him - here take mine!! Lol
Old Jul 9, 2016 | 07:33 AM
AKKutz's Avatar
AKKutz
Anyone (Bill) have optimum specs for front and rear without removing shims? The dealer who borrowed the tools from GM are going to align my car this Monday.
Old Jul 10, 2016 | 09:41 AM
Newton06's Avatar
Newton06
What is the purpose of removing the washers from the front UCAs?
My shop was able to attain the track specs but did not remove them.
Still trying to find a dealer that has the tools to check/adjust rear castor.
Thanks.
To Track alignments
