C7 frame welding
Old Jul 16, 2016 | 01:15 PM
Luke42_02's Avatar
Luke42_02
St. Jude Donor '17
Default C7 frame welding
Does anyone have experience welding a C7 frame?
I need to replace the front and rear bumper bar on my 2015 Z51. The welds are pretty simple and the service manual is very descriptive. However, you need a pulsed mig welder and I have not been able to find someone who has one locally. Just need to ask someone with experience a few questions.
Old Jul 16, 2016 | 01:40 PM
wstaab's Avatar
wstaab
You need a TIG welder to weld aluminum.
MIG welders are DC current. Good for stainless steel.
Aluminum requires AC current. TIG welders are AC and DC current switchable.
Old Jul 16, 2016 | 05:56 PM
robert miller's Avatar
robert miller
Old Jul 16, 2016 | 06:18 PM
douniasg's Avatar
douniasg
I am pretty sure the frame is welded with mig.
Old Jul 16, 2016 | 10:26 PM
RpeterK's Avatar
RpeterK
Originally Posted by douniasg
I am pretty sure the frame is welded with mig. My buddy welded my whole front frame with a mig and spool gun. Welds looked identical to factory welds.
Yes they are mig welded along with the torque tube and the driveshafts also. Very common method especially for production.
Old Jul 17, 2016 | 12:10 AM
Luke42_02's Avatar
Luke42_02
St. Jude Donor '17
Yes, 100% sure it is mig, the manual tells you the specific wire to use. My question is can I do it with regular mig, or does it have to be pulsed mig like the manual says. A Pulsed mig welder costs 5k minimum.
Old Jul 17, 2016 | 11:27 AM
corv1998's Avatar
corv1998
Default welding alum
Welding alum with mig depends on the filler metal being used . If your welding with 4043 filler metal then any spool mig can be used. 4043 is a general welding wire .The difficulty is when you use 5356 filler . A pulse machine is best for this wire . You will see the difference in it . 5356 is a wire mainly used on structural weldments. If at all possible use a pulse machine anytime your welding now a days, much better ,less heat applied to the welded zones. Your local welding supply shops often rent them , just need a experienced welder and go to it.
Old Jul 17, 2016 | 11:17 PM
RpeterK's Avatar
RpeterK
Luke42
your messages folder is full
Old Jul 18, 2016 | 12:40 AM
Luke42_02's Avatar
Luke42_02
St. Jude Donor '17
Sorry, inbox cleared now. The manual calls for 5554
Old Jul 18, 2016 | 02:08 PM
corv1998's Avatar
corv1998
Default Welding c 7 frame
If using 5554 wire then for sure you would need a pulse machine. Call around and see if you can rent one.
Old Jul 18, 2016 | 06:55 PM
bigsapper's Avatar
bigsapper
Just curious, is this frame repair or you doing something to make it go more better?
Old Jul 18, 2016 | 07:17 PM
Luke42_02's Avatar
Luke42_02
St. Jude Donor '17
No, I bought a wrecked 2015 Z51 3LT for 14k so it needs a lot of work. The front bumper bar is dented in the middle (frame rails measure correctly though) and the rear bumper bar was ripped off. The last 2-3 inches of the rear frame rails are crushed inward, but the cool thing about the new Aluminium frame is that it is made up of 1.5 foot segments which are welded together at the factory. So, on those two rear segments, I just need to cut the old welds and weld in a new segment.
To C7 frame welding
