Catch Cans
Not many say it's a bad idea though, except for the possibility of restricting vacuum or being the guy that doesn't empty the can. And I found it hard to dispute (and so did everyone they challenged apparently) all the tech arguments posted by CoSpeed, one of the can vendors.
After all my homework, I'm going with either Colorado Speed or the Elite II system, both with the clean side separator.
I am certain that would be very good if this garbage were shoved down the intake.
http://www.eliteengineeringusa.com/c...oil-separator/
Single can systems max at 1500hp unless we are fighting some unusual circumstance.Not many say it's a bad idea though, except for the possibility of restricting vacuum or being the guy that doesn't empty the can. And I found it hard to dispute (and so did everyone they challenged apparently) all the tech arguments posted by CoSpeed, one of the can vendors.
I would not let anyone that sells catch cans for a living tell you which one is the best. (I sell catch cans for a living) Listen to satisfied and dissatisfied customers.
When the crankcase becomes pressurized the flow direction in the 'clean side' reverses, likely dragging oil along with it.
The MMS cans happen to release crankcase pressure directly from the source. Because this pressure never builds, it is never redirected, it does not contaminate the clean side, and does not require more parts be purchased to deal with it.
here is a cool couple videos
and
Solutions for the common gearhead #made in USA
mightymousesolutions.com
facebok.com/mightymousesolutions
#mmsolutions
Six time NMCA True Street Champions
Home of the first Twin Turbo C7Z 7.81 @ 176
3470# Stock bottom end and heads Corvette Stock Bottom End Record Holder
Both have available with a clean side oil separator for the dry sump models.
If you have a supercharger, it seems the breather tank setup is more popular. The two most popular I have seen discussed are the Lashway Motorsports (LMR) version, and the Florida Speed and Power (FSP) version. I think FSP may be out of business now though... not sure.
Wouldn't the dry sump engine have a lot less oil mixing with the blow by so less need for a catch can?
aside from crankcase pressure to push the oil out, the only other thing that causes clean side contamination on its own would be an undersized or dirty air filter, that sucks the oil out. (This is an air filter problem not a catch can or engine problem).
all us catch can guys have a secret recipe inside our cans, mine has 4 stages
1. a wall that fast moving fumes will slam into, driving some liquid out
2. metal mesh to provide surface area for slower moving mist to condense
3. series of straining plates to improve collected liquid splashes and drips from creeping up
4. optional high efficiency exit which filters to 100 microns
just keep in mind if you open the can, the rainbow beams will escape and the unit must be destroyed!
