So I have a base 16 stingray A8 and I had a shop (reliable well known LS shop) do some work. Consisted of intake, headers, x pipe, trans cooler, flex fuel sensor, cam, pushrods, springs, chain, DOD and AFM delete, etc. Once everything was done the car started up right away and everything was great except for the idle, obviously. Didn't drive it, didn't rev it, nothing. Just started, made sure everything was fine and turned off right away.
It got towed to the tuner and upon starting it to verify that everything was fine they realized there were some codes thrown being P0340, P011, and P2089. The car itself was fine, started fine, idled relatively ok, and the tuner really thought it was just some temp codes, cleared them, and started over again but they came back. The car got towed back to the shop that did the work and they are now going to start diagnosing it but everyone is confused since everything seemed to be fine. They are going to start removing the chain cover and see if maybe a cam sensor failed.
They are well known for work on everything <C6 and is the first C7 they work on. They have done LSX swaps, whole motor rebuilds, trans rebuilds, and just about everything. So I'm not really concerned that they don't know what they're doing. But since it is the first one they do a cam swap on we're looking for some help.
Any advice would be appreciated. I forgot the exact specs of the cam but it is pretty much the most aggressive cam we can run without upgrading the converter.
Thanks guys
they left the VVt tables stock.... Tell them to zero out the table from 3k down and it will be fixed
seriously? Don't play with me emotions. Is it really that easy? Lol
yep... Problem is the factory cam has a lot more movement to it compared to the aftermarket phaser... So on the stock table where it moves quite a bit more causes a problem with an aftermarket cam.
I'm waiting on him to call me back to have him try it. If this is it, I owe you a beer. If you're in SoCal lol
Ask your tuners if the codes say (Permanent) after the description in the scanner. If so, and there are no fresh instances of the code then they are fixed, but the code itself will not go away. The Permanent listing of the codes do not turn on the CEL and they will only go away after a long time.
ill ask him in a few. He's tuning right now but I really hope they know this. It seems like basic stuff one would know after doing this for so long.
Ok, I read this was the first C7, but you were talking about the wrench.
Permanent codes are newly displayed, let's put it that way.
well I just got off the phone with the tuner and he told me everything. The car wouldn't start initially and that concerned him. He got it to start on the second try but backfired really loudly as soon as it started. Got the codes. Tried to see if it was the VVT table and wasn't. Left the car alone for the night since it was late. Next day the car wouldn't start until the 3rd attempt and there more codes and also backfired extremely loudly upon start. Checked the codes and shut the car off for good and had it towed back to the original shop. None of that was ever mentioned to me. He thinks the cam sensor and actuator are bad probably from wen installing the chain cover back on. Going to keep quiet and check the car out tomorrow and hope nothing is too bad.
I'm so angry and feel betrayed because I wasn't told anything that had happened.
Yes obviously mechanical with all that new info. No use feeling angry and betrayed, I doubt the lack of communication was personal. Enjoy life, it's just a car and tomorrow's a new day and it will get fixed.
If all that's the issue... You have more problems than vvt table then
well I wouldn't feel as bad if it weren't for the lying. I was initially told it was a 3 day job, then 2 weeks and it's now going to be 10 weeks Saturday. When I asked if everything was ok he said the car started up right away at his shop yet the tuner has texts where he asks him what could be wrong because it wouldn't start after closing it up. And he never mentioned anything that happened at the tuners except that the car started up fine, idled fine, but just threw CELs and they took it back to be safe.
Which shop performed the installation and who is your tuner? Since the shop that performed the installation differs from the tuner, I hope that the "blaming game" does not ensue. Good luck!
PS: You are in great hands with Ben and Cody attempting to assist, especially with the both of them coming together.
