So I know the coolant level should be checked when the engine is cold. However what SHOULD the level be when at normal operating temperature. Dumb question but please read on.
The reason why I ask is as follows. I recently had my coolant changed by my local dealer. Now I can see coolant in the under-the-hood tank but it is below the fill line. When I go to the dealer and ask them to fill it up properly the engine may still be warm if they jump right on it. So can I tell when warm if the right level is in the system? Presumably higher than the cold fill line??
Take the car back and tell them it's below the line when cold, tell them to fill it up properly and of course wait until it's cold so it can be done properly.
Originally Posted by Avanti
One only loses coolant if it goes somewhere other than staying in the coolant system. I know that sounds obvious, but true. Hence, if one needs to top off the system it is either leaking somewhere or being forced out the overflow from either a faulty pressure cap and/or overheating. Just saying...
Really? Before the coolant went about half inch below the line, and now it's a little bit below the line again. My ford focus does the same every once awhile and other focus owner have the same problem.
Anyone else have to fill up the coolant once awhile? (and it's not leaking and it just goes below the min level every few k miles)
Originally Posted by madrob2020
If you see coolant in the tank when cool it’s good. I think you’re splitting hairs, it’s not enough to worry about. 👍
Don't you need to fill it up to the line if the level is below that line? That's what manual says, or as long as you see there is some coolant in the tank, then no problem it's all good? But how low should you refill it then?
I'm just speculating that the amount to bring it up to Fill line from where he/she sees it would be minuscule IMO.
