LT1/LT4 engine intergity?
Old Oct 5, 2016 | 06:59 AM
Spulbus2013's Avatar
Spulbus2013
Default LT1/LT4 engine intergity?
I'm pretty sure the LT1/LT4 use the same block and crankshaft or am I mistaken?
Can anyone shed some light on what the LT1/LT4 blocks strengths and weaknesses are? What rwhp can a stock displacement, stock sleeved LT1/LT4 motor with upgraded forged internals hold before needing aftermarket sleeves?
What about the stock crankshaft, is that unit fine for 1300+whp with a blower or does everyone move to an aftermarket crank at those power levels?
Old Oct 5, 2016 | 09:09 AM
Kamran's Avatar
Kamran
Here's a technical report:
https://www.corvetteforum.com/forums...t4-vs-lt1.html
Old Oct 5, 2016 | 11:45 AM
C7&7's Avatar
C7&7
There is a lot of discussion on this here on the forum.
The LT1 does have a forged crank and rods, but the pistons are not and that makes them the weak link in the LT1. Without changing the pistons people are running about 700 wheel and <10psi of boost. With forged pistons the sky is kind of the limit. All kinds of cars out there just with the forged drop ins making 900-1100 to the tire. Stock block, stock crank, stock rods, just drop in forged pistons.
The LT4 seems to just be everything we wanted in the LT1 when it comes to the short block . Everything is forged, and there are many many 1000+ rear wheel cars out there.
The issues you're going to run into at 1000+ HP is fuel delivery, not can the physical rotating assembly take it.
Old Oct 5, 2016 | 02:29 PM
Spulbus2013
Yeah I've seen all that info but thanks. Mainly want to know has anyone broken a stock crank yet if so what power level? Has anyone cracked the stock sleeves or block yet and at what power level? Yeah so far I am gathering most of the shops ARENT needing to sleeve these motors to make decent power (1100-1200whp)
I come from the mod world (coyote) and in order to make over 1000whp with the coyotes you need to sleeve the motors at which point ur gonna be fine to make 1500+whp without fear of pushing through the water jackets. Same with the OEM cranks, they are solid units and can handle a lot of rpm and power.
Old Oct 5, 2016 | 08:15 PM
david.a8.z51's Avatar
david.a8.z51
You shouldn't have a problem with block integrity and the crankshaft is strong, but I would advise an arp main stud kit. GM has had problems with the main caps moving. If you're interested in 1500 horsepower, I would still go ahead and do a full rotating assembly, especially if boost is the way you want to go. Get a nice lower compression rotating assembly and have those rings gapped right for boost. It's not that you necessarily have to but LT engines are so much cheaper to build than mod motors, I would just go ahead and do it the right way, especially if we're talking the LT1. having said all that, I've not heard of any crankshaft breakage or block breakage at any power level. I have witnessed the main cap issue though, at high levels.
Old Oct 5, 2016 | 10:31 PM
Spulbus2013
Awesome response, Thanks! Yeah if I Build it's gonna be ARP everywhere as I've heard those same issues with the caps. Yeah I agree, I'm partially attracted to the entry fee or lack of for the LT1/LT4 world as my last coyote was over the $20k mark which is fine cause they do hold a buncha power and will last but if I can find the same or better performance in the C7 world I'll probably end up building
Old Oct 11, 2016 | 03:53 AM
ajrothm's Avatar
ajrothm
The rods are not forged in either the LT1 or LT4. They are powder metal rods. The PM rods in the LT4 are different and have extra machining on them. The LT4 also has a different forging on the crank and does have forged pistons. The LT1 has hypereutectic pistons, PM rods and forged crank. The LT1 also has a bigger camshaft.
Basically, the LS9 from the ZR1 got all of the good ****.... they cheaped out on the LT1/LT4...
That being said, I'm sure LT1 and LT1 crank will handle 900 rwhp pretty easy..
There are quite a few 900-1000 rwhp LT4s running around..Hell a couple at 1200+ on stock bottom end, but probably time bombs.
Old Oct 11, 2016 | 04:06 AM
ajrothm's Avatar
ajrothm
NO WAY would I try to make 1300 rwhp on a stock forged crank spinning a blower... You will flex it for sure.
Hell I flexed a Callies Compstar 4340 4" crank at less then 900 rwhp spinning an F1R in an LS. You're gonna need a DragonSlayer to safely support 1300 rwhp spinning a blower.... (remember, its gonna take 250hp+ to spin the blower, plus the drivetrain losses...so you are talking 1700+ crank HP)
As far as the block is concerned, that has been several LT4 blocks making 1100+ rwhp (with a blower) so the blocks seem pretty strong.
I think I would go with a stock stroke Dragonslayer or even a Billet crank in a stock LT4 block to make 1300rwhp...and ofcourse Ultra Billet rods and forged pistons.
Old Oct 12, 2016 | 12:26 AM
david.a8.z51
​​​​​​​The rods in both LT versions are forged. Just not forged steel.
Old Oct 19, 2017 | 12:21 AM
Riderover50's Avatar
Riderover50
Default LT1 Rods not forged
The LT1 connecting rods are not forged but are actually pressed Powdered Metal !
Old Oct 19, 2017 | 07:27 AM
FYREANT's Avatar
FYREANT
I'm Batman..
Pro Mechanic
Correct.
Incorrect. The rods are "forged powder metal". While they are indeed powder metal, they are still forged.
Old Oct 19, 2017 | 08:34 AM
NSC5's Avatar
NSC5
Originally Posted by FYREANT
Correct.
And this is the same forged powder metal technology that GM has been using for the connecting rods in its Duramax line of diesel engines and they hold up very well in that environment. A diesel engine with its abrupt rise in cylinder pressure puts far more stress on rods than a gasoline powered engine; especially a turbo-diesel V8 generating 910 foot pounds of torque.
Old Oct 19, 2017 | 01:24 PM
Bad Jake28's Avatar
Bad Jake28
is a 4" crank more susceptible to flex than the factory 3.62 throw? Just curious as i run a forged 4" in my 416. It's a Manley crank
Old Oct 19, 2017 | 04:11 PM
JHEBERT's Avatar
JHEBERT
+2 on the much better dragonslayer cranks, the compstar crap is forged at "offshore facilities" (china, etc).
Old Oct 19, 2017 | 05:04 PM
Riderover50
Correct.
I have to admit even though being a mechanical engineer Ive not kept up to the tech on metal alloys!
Typical PM parts are cold pressed.
Sintered (not to be confused with forged) are formed by pressing a preheated powdered metal
POWDER FORGING is a process in which unsintered, presintered, or sintered powder metal preforms are hot formed in heated confined dies.
Old Oct 19, 2017 | 05:59 PM
robert miller's Avatar
robert miller
On a stoked crank the down side with this on a motor with a blower you do know that the piston is going DOWN lower in the block. That is the down side... Robert
Old Aug 3, 2019 | 11:20 PM
J.A.M Enterprise's Avatar
J.A.M Enterprise
2nd Gear
Default lT1
I had a vvt3 Texas speed cam with all the goodies blew a chunk off the head sucked it into cylinder 5 n cracked the block not a fan anymore now I have to dump money into a new block
To LT1/LT4 engine intergity?
Old Aug 9, 2019 | 03:34 PM
thrilled's Avatar
thrilled
I had read the rods are forged.I forgot where I read it at
Old Aug 9, 2019 | 06:20 PM
Doctor Mark's Avatar
Doctor Mark
Rods are not forged. Would be better still if they were titanium to increase strength and decrease weight.
Old Aug 9, 2019 | 10:25 PM
FYREANT's Avatar
FYREANT
I'm Batman..
Pro Mechanic
You are both right. Rods are “sort of” forged lol. They are forged powder metal. Reliable up to about 850 rwhp.
